LG 38UC99-W 38" 3840x1600 5ms Curved IPS HDMI DP Monitor
Quicklinx: CQB4WS00 Mfr#: 38UC99-W
The world's first 38-inch curved IPS monitor. The 21:9 curved UltraWide QHD+ IPS Display is ideal for designers, photographers, producers and other creative professionals who need more room for big ideas. With exceptional picture quality and innovative features, this UltraWide monitor is for seriously professional creative talents.
The Wide Quad High Definition+ (WQHD+) resolution is four times clearer than basic HD, for stunning picture quality. Designed for display of advanced graphics on a wide screen, WQHD+ delivers an amazing 3840 x 1600 pixels.
With FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. FreeSync nearly eliminates tearing and stuttering that can occur because of differences between a graphic card's frame rate and a monitor's refresh rate.
  • 38 inch UltraWide curved display
  • QHD+ screen resolution
  • FreeSync
  • 1ms Motion Blur Reduction
    A monitor's response time is absolutely critical in games. The 1ms Motion Blur Reduction feature will allow gamers to enjoy the precision and accuracy needed to play at a very high level. With a response time that is virtually 1ms, blurring and ghosting are dramatically reduced to make the in-game action smoother and gamer reactions more
  • USB Type-C & USB 3.0 quick charge
    Display 4K video, transfer data and charge a laptop or mobile device, all at the same time using a single cable with USB Type-C. Charge the battery of a connected device quickly using the USB 3.0 port. This port charges compatible devices much faster than typical USB 2.0 cables so waiting for a full charge doesn't hold you up.
  • Bluetooth audio with rich bass
    With a Bluetooth connection, enjoy the music from a mobile device right through the monitor's built-in speaker (10 W x2). The monitor's speaker delivers powerful and vivid sound quality enhanced by LG's Rich Bass function that covers sound under 85 Hz for richer sound with impressive bass depth.
  • sRGB Over 99%
    sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
LG 38UC99-W - LED monitor - curved - 38"
LED-backlit LCD monitor - 38"
Energy Class
Class B
Energy Consumption per Year
72 kWh
Power Consumption (On mode)
50 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
24:10
Native Resolution
3840 x 1600 (DisplayPort: 60 Hz, HDMI: 30 Hz)
Pixel Pitch
0.2299 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
99% sRGB
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Black front panel, white (back), silver/white stand
89.72 cm x 23.04 cm x 46.62 cm
9.3 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV, EN 61000-3-3, EN55024, DDC/CI, RoHS, Directive 2004/108/EC, Directive 2006/95/EC, EN 61000-3-2:2006, EN 60950-1:2006, EPA 6.0, EN55022:2006 Class B, CE/EMC
Display Type
Energy Class
Class B
72 kWh
Diagonal Size
38"
Viewable Size
37.5"
Curved Screen
Yes (2300R)
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
24:10
Native Resolution
Pixel Pitch
0.2299 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 101 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Picture in picture, game mode, Mega Dynamic Contrast Ratio, Multiscan Support, On-screen Digital Controls, 4-screen split, Flicker Safe, Reader Mode, Dual Link-up, SIX Axis Control, Mercury free, Motion Blur Reduction, Factory Calibration, MaxxAudio, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), My Display Preset, USB 3.0 Quick Charge, Bluetooth Audio, 99% sRGB colour gamut
89.72 cm x 23.04 cm x 46.62 cm - with stand
9.3 kg
Audio
Speakers - stereo
Output Power / Channel
10 Watt
2 x HDMI , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , Audio line-out , USB-C
Mechanical
Height, tilt
Tilt Angle
-5/+15
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Cable holder
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C cable - 1 m , 1 x USB cable
Input Voltage
50 W
Power Consumption (Typical)
57 Watt
Power Consumption Stand by
1.2 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Screen Split Software, Dual Controller Software
Apple MacOS X
Dimensions & Weight Details
With stand - width: 89.72 cm - depth: 23.04 cm - height: 46.62 cm - weight: 9.3 kg , Without stand - width: 89.72 cm - depth: 9.15 cm - height: 39.3 cm - weight: 7.7 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 2 years - carry-in
