LG 34UC99-W 34" 3440x1440 5ms VGA DVI HDMI DisplayPort LED Monitor
Quicklinx: D8KQWS00 Mfr#: 34UC99-W
This IPS display offers amazingly sharp picture quality. This wide display is ideal for photographers, producers and other creative professionals who need more room for big ideas.
  • IPS display
    IPS technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can view the screen at virtually any angle.
  • USB Type-C connectivity
    Offering more convenience, USB Type-C ports allow Ultra HD video display, data transfer and laptop/mobile device charging, all at the same time over a single cable. Reduce cord clutter and increase efficiency with USB Type-C.
  • FreeSync
    With FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. FreeSync nearly eliminates tearing and stuttering that can occur because of differences between a graphic card's frame rate and a monitor's refresh rate.
  • Reader mode
    Reducing blue light to help lessen eye fatigue, reader mode provides optimal conditions for reading. With just a click of a mouse, you can more comfortably read your display.
LG 34UC99-W - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class G
Energy Consumption per Year
76 kWh
Power Consumption (On mode)
52 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
UWQHD 3440 x 1440 at 60 Hz
Pixel Pitch
0.232 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.073 billion colours (8-bit)
Colour Gamut
99% sRGB
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Grey, white
81.76 cm x 25.94 cm x 48.28 cm
8.4 kg
Plug and Play, FCC Class B certified, UL, EN 61000-3-3, EN55024, EMC, DDC/CI, RoHS, Directive 2004/108/EC, Directive 2006/95/EC, EN 61000-3-2:2006, EN 60950-1:2006, EN55022:2006 Class B
Display Type
Energy Class
Class G
76 kWh
Diagonal Size
34"
Curved Screen
Yes (1900R)
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.232 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Picture in picture, picture by picture, Picture Mode, game mode, Multiscan Support, On-screen Digital Controls, Flicker Safe, Reader Mode, Dual Link-up, SIX Axis Control, Factory Calibration, MaxxAudio, Smart Energy Saving technology, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), My Display Preset, Color Weakness Mode, Dark Room mode, USB 3.0 Quick Charge, 99% sRGB colour gamut
Grey, white
81.76 cm x 25.94 cm x 48.28 cm - with stand
8.4 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
USB-C , 2 x HDMI , DisplayPort , 2 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
Height, tilt
Tilt Angle
-5/+15
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Cable holder
1 x DisplayPort cable , 1 x HDMI cable , 1 x USB-C cable - 1 m , 1 x USB cable - USB Type A to C
Input Voltage
52 W
40 kWh/1000h
Power Consumption (Typical)
70 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 81.76 cm - depth: 25.94 cm - height: 48.28 cm - weight: 8.4 kg , Without stand - width: 81.76 cm - depth: 8.87 cm - height: 36.08 cm - weight: 6.4 kg
