LG Public Display TV's are designed to enhance any business application. The LW340C has a simple user-friendly interface, superb images and video that helps facilitate any communications between businesses and their target audiences.
PUBLIC DISPLAY MODE
From channel selection to energy-saving features, Public Display Mode allows you to control the TV settings in your business area, prevent misuse by customers, set volume limits, or restore factory defaults on any TV. You are in control of it all.
USB CLONING
The USB Cloning feature allows you to simply copy the TV settings onto all TVs using a USB stick, a process that is fully automated to save time without having to set each TV one by one.
WELCOME SCREEN
Welcome visitors with a warm greeting message that includes your business name/logo and now with a video or both.
LOCK MODE
The Lock Mode blocks external input signals for illegal communication, a useful feature for preventing misuse of TVs in facilities such as prisons, mental hospitals and other applicable public spaces.
EXTERNAL SPEAKER OUT
Enhance the entertainment experience by adding an additional speaker, visitors to listen to and control the TV audio from anywhere in your business area, including restrooms.
- LG Commercial Lite 32LW340C 32" LED-backlit LCD TV - Full HD - for hotel / hospitality
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 32"
- Commercial Use
- Yes - hotel / hospitality
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Frame Rate & Enhancement Technology
- 60 Hz Frame Rate
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15)
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Commercial Features
- Screen welcome message, prison mode, Remote Diagnosis, Lock Mode
- Settings Cloning Capability
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A+
- Power Consumption (On mode)
- 30 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 44 kWh
- Dimensions (WxDxH) - without stand
- 73.3 cm x 7.22 cm x 43.6 cm
- Product Type
- Energy Class
- Class A+
- 30 W
- 44 kWh
- Diagonal Class
- 32"
- Commercial Use
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- VGA (HD-15)
- Modes
- Expert mode, hotel mode
- Dimensions
- Without stand
- 73.3 cm
- 7.22 cm
- 43.6 cm
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- 60 Hz Frame Rate
- Direct-lit LED
- Brightness
- 300 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Backlight Life
- 50,000 hour(s)
- XD Engine technology, Eco Flower, One Channel Map, security lock slot (cable lock sold separately), RJP Compatible
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 200 x 200 mm
TV Tuner
- Conditional Access
- Common Interface (CI) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
- Digital TV Service
- TNT HD
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
Media Player
- Supported Video Formats
- DivX HD
- Supported Audio Formats
- MP3, PCM, AC3, AAC, HE-AAC, E-AC3
- Supported Pictures Formats
- MPO, JPS, JPEG
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Clear Voice technology, Invisible Speaker System
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Supported Consumer Electronics Control (CEC)
- Simplink
- Connector Type
- Speakers output , Headphones , Composite video / component video input , VGA input , 2 x HDMI input , Serial input , Digital audio output (optical) , LAN , USB 2.0
- CB, EMC, RoHS, CEC, ERP, CU-TR
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- Smart energy saving
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 73.3 cm x 7.22 cm x 43.6 cm , Panel with stand - 73.3 cm x 28.2 cm x 49 cm x 8.17 kg
- Width (Shipping)
- 81.2 cm
- Depth (Shipping)
- 19 cm
- Height (Shipping)
- 52 cm
