32" LG HD LED TV
Key Features
Picture Mastering Engine
Improve any image with Resolution Upscaler
Virtual Surround Sound
USB Connectivity
Built-In Games
Enjoy any image with LG's Resolution Upscaler, which enhances and optimizes the image no matter the picture quality. -
Virtual surround sound
High-quality TV creates a surround sound effect, producing virtual audio channels for broadcast and digital programs. Surround your senses with sound from all angles. -
USB connectivity
Simply insert a USB stick or external hard drive, containing videos, photos and music into the USB port to play and view the files. -
Convenient connectivity
Plug and Play. With multiple inputs you can plug in your HDMI cable or USB and play out your entertainment, games or digital devices through your TV.
- LG 32LJ510B 32" LED-backlit LCD TV - HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 32"
- Resolution
- 1366 x 768
- Display Format
- 720p
- Frame Rate & Enhancement Technology
- 300 Hz Picture Mastering Index
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-T
- Picture Enhancements
- Resolution Upscaler, Color Master Engine
- Sound Effects
- Virtual Surround Mode
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A+
- Power Consumption (On mode)
- 29 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 40 kWh
- Dimensions (WxDxH) - without stand
- 73.9 cm x 8.4 cm x 44.1 cm
- 4.85 kg
- Product Type
- Energy Class
- Class A+
- 29 W
- 40 kWh
- Diagonal Class
- 32"
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 2 ports
- Dimensions
- Without stand
- 73.9 cm
- 8.4 cm
- 44.1 cm
- 4.85 kg
Display
- Resolution
- 1366 x 768
- Display Format
- 720p
- 16:9
- Direct-lit LED
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 200 x 200 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- DVB-C, DVB-T
Video Features
- Teletext
- Teletext Memory
- 2000 pages
- Electronic Programme Guide
- Digital EPG
Media Player
- Supported Video Formats
- HEVC
- Supported Audio Formats
- MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, MP2
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Surround Mode
- Sound Effects
- Output Power / Total
- 10 Watt
- Clear Voice technology
Network & Internet Multimedia
- Connectivity
- LAN
- Supported Consumer Electronics Control (CEC)
- Simplink
- Connector Type
- 2 x HDMI , USB , Composite video / component video input , LAN , Digital audio output (optical)
- Batteries
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Energy save
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 73.9 cm x 8.4 cm x 44.1 cm x 4.85 kg , Panel with stand - 73.9 cm x 16.8 cm x 47.2 cm x 4.9 kg
