Discover the LG MyView 32SR50F-W, a 32-inch LED-backlit LCD monitor designed to elevate your viewing experience. With its Full HD (1080p) resolution, every detail is rendered with clarity, while the 99% sRGB color gamut delivers professional-grade color accuracy, making it perfect for designers, photographers, and anyone who values precision in color representation.
The monitor is equipped with a built-in Bluetooth adapter and USB hub, providing seamless connectivity for all your devices. Whether you're working from home or in the office, the LG MyView 32SR50F-W adapts to your setup with ease. HDR10 support ensures that you enjoy a vibrant and dynamic range of colors, bringing your content to life.
Moreover, the smart monitor capabilities of the LG MyView 32SR50F-W offer a more interactive and efficient user experience, making it a versatile choice for both work and entertainment. With its sleek design and advanced features, this monitor is an excellent addition to any space, promising both functionality and style.
Immersive color accuracy
Experience true-to-life colors with the 32-inch LG MyView 32SR50F-W monitor, featuring a 99% sRGB color gamut for professional-grade color accuracy. Ideal for designers and photographers who demand precision in their work. -
Seamless connectivity
Equipped with a built-in Bluetooth adapter and USB hub, this monitor offers seamless connectivity options for all your devices, making it a versatile addition to any workspace. -
Optimized viewing experience
With HDR10 support and a wide 178-degree viewing angle, the LG MyView 32SR50F-W ensures a vibrant and clear viewing experience from virtually any angle, enhancing your entertainment and productivity. -
Effortless adjustability
Tailor your viewing experience with easy display position adjustments including tilt, ensuring comfort during long hours of use. -
Smart monitor capabilities
Step into the future of computing with smart monitor features, allowing for a more interactive and efficient user experience. The LG MyView 32SR50F-W is more than just a monitor; it's a gateway to smart technology integration in your daily tasks.
- LG MyView 32SR50F-W - LED monitor - Full HD (1080p) - 32" - HDR
- LED-backlit LCD monitor - 32" - Smart monitor
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1702045
- Energy Class
- Class E
- USB Hub, Bluetooth adapter
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.363 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1200:1
- HDR Capable
- HDR10
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- 2xHDMI
- Tilt
- Voltage
- AC 100-240 V (50/60 Hz)
- 73.18 cm x 20.99 cm x 52.12 cm
- 6.6 kg
- Display Type
- LED-backlit LCD monitor / TFT active matrix - Smart monitor
- Energy Class
- Class E
- Energy Class (HDR)
- Class F
- Diagonal Size
- 32"
- Viewable Size
- 31.5"
- Operating System
- webOS 23
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.363 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1200:1
- HDR Format
- HDR10
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Auto Brightness Control, Flicker Safe, Smart Energy Saving technology, 8-bit(6-bit + FRC) Colour Depth, Screen Share, Dashboard, AI concierge
- 73.18 cm x 20.99 cm x 52.12 cm - with stand
- 6.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- 2 x HDMI , 2 x USB downstream
Mechanical
- Tilt
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Remote control
- Cables Included
- 1 x HDMI cable - 1.5 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 26 kWh/1000h
- Power Consumption HDR (On mode)
- 30 kWh/1000h
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.5 Watt
- Included Software
- ThinQ Home, WebOS 23
- Dimensions & Weight Details
- With stand - width: 73.18 cm - depth: 20.99 cm - height: 52.12 cm - weight: 6.6 kg , Without stand - width: 73.18 cm - depth: 4.5 cm - height: 44.05 cm - weight: 5.4 kg
- Shipping Width
- 89.2 cm
- Shipping Depth
- 13.1 cm
- Shipping Height
- 51.7 cm
- Shipping Weight
- 9 kg
