LG 32 INCH Smart WebOS 23 Monitor FHD IPS HDMI
Quicklinx: HV8DWS00 Mfr#: 32SR50F-W.AEK
Diagonal Size: 32in
Max Resolution: 1920 x 1080
Response Time: 8ms
Speakers: Speaker(s)
Interfaces: HDMI
20 In Stock
£207.50 ex VAT
£249.00 inc VAT
Discover the LG MyView 32SR50F-W, a 32-inch LED-backlit LCD monitor designed to elevate your viewing experience. With its Full HD (1080p) resolution, every detail is rendered with clarity, while the 99% sRGB color gamut delivers professional-grade color accuracy, making it perfect for designers, photographers, and anyone who values precision in color representation.
The monitor is equipped with a built-in Bluetooth adapter and USB hub, providing seamless connectivity for all your devices. Whether you're working from home or in the office, the LG MyView 32SR50F-W adapts to your setup with ease. HDR10 support ensures that you enjoy a vibrant and dynamic range of colors, bringing your content to life.
Moreover, the smart monitor capabilities of the LG MyView 32SR50F-W offer a more interactive and efficient user experience, making it a versatile choice for both work and entertainment. With its sleek design and advanced features, this monitor is an excellent addition to any space, promising both functionality and style.
  • Immersive color accuracy
    Experience true-to-life colors with the 32-inch LG MyView 32SR50F-W monitor, featuring a 99% sRGB color gamut for professional-grade color accuracy. Ideal for designers and photographers who demand precision in their work.
  • Seamless connectivity
    Equipped with a built-in Bluetooth adapter and USB hub, this monitor offers seamless connectivity options for all your devices, making it a versatile addition to any workspace.
  • Optimized viewing experience
    With HDR10 support and a wide 178-degree viewing angle, the LG MyView 32SR50F-W ensures a vibrant and clear viewing experience from virtually any angle, enhancing your entertainment and productivity.
  • Effortless adjustability
    Tailor your viewing experience with easy display position adjustments including tilt, ensuring comfort during long hours of use.
  • Smart monitor capabilities
    Step into the future of computing with smart monitor features, allowing for a more interactive and efficient user experience. The LG MyView 32SR50F-W is more than just a monitor; it's a gateway to smart technology integration in your daily tasks.
LG MyView 32SR50F-W - LED monitor - Full HD (1080p) - 32" - HDR
LED-backlit LCD monitor - 32" - Smart monitor
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1702045
Energy Class
Class E
USB Hub, Bluetooth adapter
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.363 mm
Brightness
250 cd/m²
Contrast Ratio
1200:1
HDR Capable
HDR10
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
2xHDMI
Display Position Adjustments
Tilt
Voltage
AC 100-240 V (50/60 Hz)
73.18 cm x 20.99 cm x 52.12 cm
6.6 kg
Display Type
LED-backlit LCD monitor / TFT active matrix - Smart monitor
Energy Class
Class E
Energy Class (HDR)
Class F
Diagonal Size
32"
Viewable Size
31.5"
Operating System
webOS 23
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.363 mm
Brightness
250 cd/m²
Contrast Ratio
1200:1
HDR Format
HDR10
Colour Support
Colour Gamut
99% sRGB
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Auto Brightness Control, Flicker Safe, Smart Energy Saving technology, 8-bit(6-bit + FRC) Colour Depth, Screen Share, Dashboard, AI concierge
73.18 cm x 20.99 cm x 52.12 cm - with stand
6.6 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI , 2 x USB downstream
Mechanical
Tilt
VESA Mounting Interface
100 x 100 mm
Remote control
1 x HDMI cable - 1.5 m
Security Slot Type
Kensington security slot
Input Voltage
26 kWh/1000h
Power Consumption HDR (On mode)
30 kWh/1000h
Power Consumption (Typical)
30 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Included Software
ThinQ Home, WebOS 23
Dimensions & Weight Details
With stand - width: 73.18 cm - depth: 20.99 cm - height: 52.12 cm - weight: 6.6 kg , Without stand - width: 73.18 cm - depth: 4.5 cm - height: 44.05 cm - weight: 5.4 kg
Shipping Width
89.2 cm
Shipping Depth
13.1 cm
Shipping Height
51.7 cm
Shipping Weight
9 kg
Diagonal Size: 32in
Response Time: 8ms
Interfaces: HDMI
Brand: LG
