Product
Brand
LG 29WK600-W 29" 2560x1080 5ms HDMI DP LED Monitor
Quicklinx: DL1VWS00 Mfr#: 29WK600-W
Diagonal Size: 29in
Max Resolution: 2560 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
45 in stock
£238.89 ex VAT
£286.66 inc VAT
To more fully realize content creators' vision, this monitor is compatible with industry-standard HDR 10 high dynamic range, supporting specific levels of color and brightness that exceed the capabilities of ordinary monitors. The HDR Effect helps transform non-HDR content into high quality video that looks like HDR through its picture quality algorithm.
LG 29WK600-W - LED monitor - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class A
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
UWFHD 2560 x 1080 at 75 Hz
Pixel Pitch
0.2651 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Black front, matte silver base, textured white back
69.81 cm x 20.94 cm x 41.09 cm
5.2 kg
FCC Class B certified, UL, TUV, cUL, EN 61000-3-3, EN55024, EN 61000-3-2:2006, EN 60950-1:2006, EPA 7.0, CE/EMC
2 years warranty
Display Type
Energy Class
Class A
37 kWh
25 W
Diagonal Size
29"
Viewable Size
29"
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.2651 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
HDCP, game mode, Cinema Mode, On-screen Digital Controls, 99% sRGB colour gamut, FPS Mode, 4-screen split, Crosshair Display, Flicker Safe, SIX Axis Control, RTS Mode, MaxxAudio, Smart Energy Saving technology, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), HDR (high dynamic range), HDR10 compatible
69.81 cm x 20.94 cm x 41.09 cm - with stand
5.2 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI (HDCP) , DisplayPort , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
2 screws, cable holder
1 x HDMI cable , 1 x audio cable
MTBF
50000 hour(s)
Security Slot Type
Kensington security slot
38 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 69.81 cm - depth: 20.94 cm - height: 41.09 cm - weight: 5.2 kg , Without stand - width: 69.81 cm - depth: 7.69 cm - height: 31.75 cm - weight: 4.7 kg
Shipping Width
82.2 cm
Shipping Depth
15.9 cm
Shipping Height
41.3 cm
Shipping Weight
7.5 kg
Diagonal Size: 29in
Response Time: 5ms
Interfaces: HDMI
Brand: LG
Price Range Ex VAT: 150 - 300
