HDR 10
To more fully realize content creators’ vision, this monitor is compatible with industry-standard HDR10 high dynamic range, supporting specific levels of color and brightness that exceed the capabilities of ordinary monitors.
HDR Effect
The HDR Effect helps transform non-HDR content into high quality video that looks like HDR through its picture quality algorithm.
sRGB 99%
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
Virtually Borderless Design
The ultra-thin bezel on three sides of this streamlined display offers a virtually borderless visual experience, without distraction from the precise, gorgeous image. A sleek addition to any desktop.
21:9 UltraWide Display
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
On-Screen Control
On-Screen Control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and Dual Controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor.
AMD FreeSync
With FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. FreeSync virtually eliminates screen tearing and stuttering.
Advanced Gaming Features
Serious gaming features for serious gamers. Quickly optimize monitor settings to activate Black Stabilizer to reveal superior detail in dark scenes while the Dynamic Action Sync feature assures smooth, fluid gaming action.
Sleek Design
The sleek design of LG premium monitors is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
HDR 10
To more fully realize content creators' vision, this monitor is compatible with industry-standard HDR 10 high dynamic range, supporting specific levels of color and brightness that exceed the capabilities of ordinary monitors. -
HDR Effect
The HDR Effect helps transform non-HDR content into high quality video that looks like HDR through its picture quality algorithm. -
Virtually borderless design
The ultra-thin bezel on three sides of this streamlined display offers a virtually borderless visual experience, without distraction from the precise, gorgeous image. A sleek addition to any desktop. -
21:9 UltraWide display
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them. -
On-Screen Control
On-Screen Control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and Dual Controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor. -
AMD FreeSync
With FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. FreeSync virtually eliminates screen tearing and stuttering. -
Advanced gaming features
Serious gaming features for serious gamers. Quickly optimize monitor settings to activate Black Stabilizer to reveal superior detail in dark scenes while the Dynamic Action Sync feature assures smooth, fluid gaming action. -
Sleek design
- LG 29WK600-P - LED monitor - 29" - HDR
- LED-backlit LCD monitor - 29"
- Energy Class
- Class A
- Energy Consumption per Year
- 37 kWh
- Power Consumption (On mode)
- 25 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- UWFHD 2560 x 1080 at 75 Hz
- Pixel Pitch
- 0.2628 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- HDR Capable
- HDR10
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB (CIE 1931)
- Input Connectors
- 2xHDMI, DisplayPort
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black texture, white texture, textured silver
- 69.81 cm x 20.94 cm x 41.09 cm
- 5.2 kg
- FCC Class B certified, UL, TUV, VCCI, cUL, CCC, ERP, EPA 7.0
- Display Type
- Energy Class
- Class A
- 37 kWh
- Diagonal Size
- 29"
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.2628 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- HDR Format
- HDR10
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, game mode, Cinema Mode, On-screen Digital Controls, FPS Mode, 4-screen split, Crosshair Display, Flicker Safe, Reader Mode, SIX Axis Control, RTS Mode, MaxxAudio, Smart Energy Saving technology, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync)
- 69.81 cm x 20.94 cm x 41.09 cm - with stand
- 5.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- 2 x HDMI (HDCP) , DisplayPort , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 25 W
- Power Consumption (Typical)
- 32 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 69.81 cm - depth: 20.94 cm - height: 41.09 cm - weight: 5.2 kg , Without stand - width: 69.81 cm - depth: 7.69 cm - height: 31.75 cm - weight: 4.7 kg
- Shipping Width
- 82.2 cm
- Shipping Depth
- 41.3 cm
- Shipping Height
- 15.9 cm
- Shipping Weight
- 7.5 kg
