LG 29WK600 29" 2560x1080 5ms HDMI DisplayPort USB-C Thunderbolt UltraWide IPS LED Monitor
Quicklinx: DNDPWS00 Mfr#: 29WK600
HDR 10
To more fully realize content creators’ vision, this monitor is compatible with industry-standard HDR10 high dynamic range, supporting specific levels of color and brightness that exceed the capabilities of ordinary monitors.
HDR Effect
The HDR Effect helps transform non-HDR content into high quality video that looks like HDR through its picture quality algorithm.
sRGB 99%
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
Virtually Borderless Design
The ultra-thin bezel on three sides of this streamlined display offers a virtually borderless visual experience, without distraction from the precise, gorgeous image. A sleek addition to any desktop.
21:9 UltraWide Display
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
On-Screen Control
On-Screen Control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and Dual Controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor.
AMD FreeSync
With FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. FreeSync virtually eliminates screen tearing and stuttering.
Advanced Gaming Features
Serious gaming features for serious gamers. Quickly optimize monitor settings to activate Black Stabilizer to reveal superior detail in dark scenes while the Dynamic Action Sync feature assures smooth, fluid gaming action.
Sleek Design
The sleek design of LG premium monitors is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
  • HDR 10
    To more fully realize content creators' vision, this monitor is compatible with industry-standard HDR 10 high dynamic range, supporting specific levels of color and brightness that exceed the capabilities of ordinary monitors.
  • HDR Effect
  • Virtually borderless design
  • 21:9 UltraWide display
  • On-Screen Control
  • AMD FreeSync
  • Advanced gaming features
  • Sleek design
LG 29WK600-P - LED monitor - 29" - HDR
LED-backlit LCD monitor - 29"
Energy Class
Class A
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
UWFHD 2560 x 1080 at 75 Hz
Pixel Pitch
0.2628 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
HDR Capable
HDR10
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB (CIE 1931)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Voltage
Black texture, white texture, textured silver
69.81 cm x 20.94 cm x 41.09 cm
5.2 kg
FCC Class B certified, UL, TUV, VCCI, cUL, CCC, ERP, EPA 7.0
Display Type
Energy Class
Class A
37 kWh
Diagonal Size
29"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.2628 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
HDR Format
HDR10
Colour Support
Colour Gamut
99% sRGB (CIE 1931)
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, game mode, Cinema Mode, On-screen Digital Controls, FPS Mode, 4-screen split, Crosshair Display, Flicker Safe, Reader Mode, SIX Axis Control, RTS Mode, MaxxAudio, Smart Energy Saving technology, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync)
69.81 cm x 20.94 cm x 41.09 cm - with stand
5.2 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI (HDCP) , DisplayPort , Headphones
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
25 W
Power Consumption (Typical)
32 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 69.81 cm - depth: 20.94 cm - height: 41.09 cm - weight: 5.2 kg , Without stand - width: 69.81 cm - depth: 7.69 cm - height: 31.75 cm - weight: 4.7 kg
Shipping Width
82.2 cm
Shipping Depth
41.3 cm
Shipping Height
15.9 cm
Shipping Weight
7.5 kg
