LG 29WK500 29" 2560x1080 5ms DVI HDMI DisplayPort USB-C Thunderbolt UltraWide IPS LED Monitor
Quicklinx: DNDMWS00 Mfr#: 29WK500
Diagonal Size: 29in
Max Resolution: 2560 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: HDMI
Hurry, only 3 left in stock!
£224.29 ex VAT
£269.14 inc VAT
More Space for Multi-Tasking
The 21:9 UltraWide™ Full HD resolution (2560X1080) offers more screen space compared to 16:9 Full HD resolution display. You can run multiple windows and see more thumbnail images at once.
True Colours and Wider View
LG IPS monitor displays impeccable colour accuracy. With a wider viewing angle, the IPS display boasts 99% coverage of the sRGB colour spectrum.
Unified Interface for Easy Set-up
OnScreen Control gives quick, easy access to a host of important monitor settings.
Clearer, Smoother Image
With AMD FreeSync™ Technology, gamers can experience seamless, fluid movement during hi-res, fast-paced games. FreeSync virtually eliminates screen tearing and stuttering.
Optimized settings for all games
Game Mode includes three sub-modes-FPS, RTS, and Custom- for personalizing your gaming experience or optimizing your favorite game genres.
Versatile Elegance
The curved base is an elegant style statement that also enhances stability for dependable performance. The base can be adjusted to change the tilt, height and angle of the monitor for a more comfortable viewing experience.
  • Play games with optimized settings
    Game mode includes three sub-modes - FPS, RTS, and custom - for personalizing your gaming experience or optimizing your favorite game genres.
  • Clearer, smoother image
    Gamers can experience seamless, fluid movement during high-resolution, fast-paced games.
  • Versatile elegance
    The curved base is an elegant style statement that also enhances stability for dependable performance. The base can be adjusted to change the tilt and angle of the monitor for a more comfortable viewing experience.
LG 29WK500-P - LED monitor - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class A
Energy Consumption per Year
41 kWh
Power Consumption (On mode)
28 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
UWFHD 2560 x 1080 at 75 Hz
Pixel Pitch
0.2651 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Black textured back cover, black metal base, black front
69.81 cm x 20.94 cm x 41.09 cm
5.2 kg
FCC Class B certified, UL, TUV, cUL, EN 61000-3-3, EN55024, DDC/CI, EN 60950-1:2006, EN61000-3-2:2006, EMC 2004/108/EC, LVD 2006/95/EC, EN55022:2006 Class B
Display Type
Energy Class
Class A
41 kWh
28 W
Diagonal Size
29"
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.2651 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean, UK English
Game mode, Mega Contrast, Mega Dynamic Contrast Ratio, Multiscan Support, On-screen Digital Controls, 99% sRGB colour gamut, 4-screen split, Crosshair Display, Flicker Safe, Reader Mode, Mercury free, Smart Energy Saving technology, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), My Display Preset, 6-Axis Color Adjustments
69.81 cm x 20.94 cm x 41.09 cm - with stand
5.2 kg
2 x HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), ArcLine stand
1 x HDMI cable
MTBF
50000 hour(s)
Security Slot Type
Kensington security slot
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 69.81 cm - depth: 20.94 cm - height: 41.09 cm - weight: 5.2 kg , Without stand - width: 69.81 cm - depth: 7.69 cm - height: 31.75 cm - weight: 4.7 kg
Shipping Width
82.2 cm
Shipping Depth
15.9 cm
Shipping Height
41.3 cm
Shipping Weight
7.5 kg
LG 29WK500 29 Bundle deal on LG 29WK500 29" 2560x1080 5ms DVI HDMI DisplayPort USB-C Thunderbolt UltraWide IPS LED Monitor
£323.46
Diagonal Size: 29in
Response Time: 5ms
Interfaces: HDMI
Brand: LG
Price Range Ex VAT: 150 - 300
