LG 27UD88-W 27" 1920x1080 5ms HDMI DisplayPort USB LED LCD Monitor
Quicklinx: D05VWS00 Mfr#: 27UD88-W
  • Windows 8.1 (32/64 bits)
The clarity and details with 4K Ultra HD resolution will amaze, even up close. With over 99% coverage of the sRGB spectrum this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
  • Color calibration pro
    Calibration hardware and Color Calibration Pro work together to assure accurate color, while color mode presets adapt to a variety of specific needs.
  • USB Type-C
    Display 4K video, transfer data and charge a laptop or mobile device, all at the same time using a single cable with USB-C.
  • On-screen control
    On-Screen Control makes it easy to adjust many monitor settings via an on-screen window, with a few easy clicks of your mouse.
  • Split screen 2.0
    Customize your monitor layout, resizing and displaying multiple windows at once with 14 options including PIP.
  • 4K dynamic gaming
    Experience clearer and more stable gameplay with 4K UHD resolution and FreeSync technology.
  • FreeSync
    LG's 21:9 UltraWide monitors with FreeSync technology eliminate the tearing and stuttering that have plagued gaming enthusiasts for years.
  • Black stabilizer
    Keep visibility even in dark scenes. LG's Black Stabilizer sense dark scenes and helps make it brighter so that you can find the enemies hiding and waiting to attack your player in the dark.
  • Arcline design
    The sleek design of LG premium monitors is accentuated by the new ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
LG 27UD88-W - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1557 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
99% sRGB
Input Connectors
2xHDMI, DisplayPort, USB
Display Position Adjustments
Height, pivot (rotation), tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
White, silver
61.5 cm x 22.26 cm x 42.52 cm
6.2 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, C-Tick, cUL, SEMKO, EN 61000-3-3, EN55024, DDC/CI, Directive 2004/108/EC, Directive 2006/95/EC, EN 61000-3-2:2006, EN 60950-1:2006, EPA 6.0, DIN ISO 9241-307, EN 55022 Class A
3-year warranty
Display Type
Energy Class
Class A
44 kWh
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1557 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
SUPER + Resolution, game mode, On-screen Digital Controls, TrueColor Pro, 4-screen split, Dual Link-up, SIX Axis Control, Factory Calibration, Smart Energy Saving technology, New CINEMA Screen Design, Color Calibrated, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), sRGB Color Space, My Display Preset, USB 3.0 Quick Charge
White, silver
61.5 cm x 22.26 cm x 42.52 cm - with stand
6.2 kg
2 x HDMI , DisplayPort , 2 x USB 3.0 downstream , Headphones , USB-C
Mechanical
Tilt Angle
-5/+35
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), ArcLine stand
1 x DisplayPort cable , 1 x HDMI cable
Input Voltage
30 W
Power Consumption (Typical)
39 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Microsoft Windows 7 (32/64 bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.10 or later
Dimensions & Weight Details
With stand - width: 61.5 cm - depth: 22.26 cm - height: 42.52 cm - weight: 6.2 kg , Without stand - width: 61.5 cm - depth: 4.27 cm - height: 36.51 cm - weight: 4.7 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
