LG 27MP38VQ-B 27" 1920 x 1080 5ms VGA DVI LED
Quicklinx: CV0TWS00 Mfr#: 27MP38VQ-B
IPS (In-Plane Switching) technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle.
On-screen control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and dual controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor.
  • Full HD IPS display
  • On-screen control
  • Screen split 2.0
    Customize your monitor layout for multitasking with the latest version of LG screen split. Resize and display multiple windows at once, with 14 options including four different picture-in-picture (PIP) choices.
  • Reader mode
    Reducing blue light to help lessen eye fatigue, Reader Mode provides optimal conditions for reading. With just a click of a mouse, you can more comfortably read your display.
LG 27MP38VQ-B - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Input Connectors
HDMI, DVI, VGA
Voltage
AC 120/230 V
64.14 cm x 4.82 cm x 39.3 cm
3.9 kg
Plug and Play, DDC/CI
3-year warranty
Display Type
Energy Class
Class A
34 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
SUPER Energy Saving Technology, 4-screen split, Multilingual On Screen Display
64.14 cm x 4.82 cm x 39.3 cm - without stand
3.9 kg
VGA , HDMI , DVI-D , Headphones
Mechanical
VESA Mounting Interface
100 x 100 mm
Input Voltage
AC 120/230 V
23 W
Power Consumption (Typical)
27 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Without stand - width: 64.14 cm - depth: 4.82 cm - height: 39.3 cm - weight: 3.9 kg , With stand - width: 64.14 cm - depth: 20.3 cm - height: 45.97 cm - weight: 4.4 kg
Limited warranty - 3 years
CV0T StarTech.com Dual Monitor Mount - Stackable In Stock £213.39
CV0T StarTech.com TV/Monitor Arm - Wallmount In Stock £82.22
CV0T StarTech.com Monitor Arm - Heavy Duty In Stock £93.15
CV0T StarTech.com Monitor Desk Mount - Steel In Stock £43.93
