LG 27BK750Y 27" 1920x1080 5ms DVI HDMI DisplayPort Monitor
Quicklinx: DN99WS00 Mfr#: 27BK750Y
Designed for professionals, this Full HD display with IPS technology minimizes color shifts and provides outstanding picture quality from virtually any viewing angle.
The three-side borderless screen minimizes the bezel so the display blends seamlessly into any workspace. It enhances the sense of immersion and adds aesthetic appeal.
  • Full HD IPS display
  • A sense of immersion with borderless design
  • Personalized viewing angles and easy assembly
    The monitors provide comfortable viewing with versatile screen height/tilt/pivot/swivel adjustments. You can customize the display condition to create a more personal, comfortable workstation.
  • Easy to duplicate and extend screen with daisy chain
    The Daisy Chain lets you connect up to four monitors with duplication and extension functions. This setup creates synergy, allowing efficient resource sharing throughout an organization.
LG 27BK750Y - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
25.2 W
Daisy Chaining
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.314 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Anthracite dark
61.15 cm x 27.61 cm x 54.29 cm
7.6 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, cUL, CB, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, REACH
Display Type
Energy Class
Class F
34 kWh
Diagonal Size
27"
Daisy Chaining
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.314 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Hindi, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
Power off timer, HDCP, split screen, On-screen Digital Controls, Flicker Safe, Reader Mode, SIX Axis Control, Mercury free, Smart Energy Saving technology, New CINEMA Screen Design, Color Calibrated, Response Time Control, Color Weakness Mode, USB 3.0 Quick Charge, borderless, One Click Stand
Anthracite dark
61.15 cm x 27.61 cm x 54.29 cm - with stand
7.6 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
HDMI , DVI-D , Headphones , DisplayPort , 2 x USB 3.0 downstream , USB 3.0 upstream , Audio line-in
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), PVC free
Stand, cable holder
1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable - 1.8 m
Backlight Life
50,000 hours
MTBF
50,000 hour(s)
Input Voltage
25.2 W
25.2 kWh/1000h
Power Consumption (Typical)
23 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.005 Watt
Dimensions & Weight Details
With stand - width: 61.15 cm - depth: 27.61 cm - height: 54.29 cm - weight: 7.6 kg , Without stand - width: 61.15 cm - depth: 5.9 cm - height: 36.75 cm - weight: 4.9 kg
Sustainability Information
ENERGY STAR Certified
