LG 27BK550Y 27" Full HD IPS Monitor
Quicklinx: DN96WS00 Mfr#: 27BK550Y
Designed for professionals, this Full HD display with IPS technology minimizes color shifts and provides outstanding picture quality from virtually any viewing angle.
The power module is integrated with the monitor, helping to reduce the amount of power modules in your workspace.
The monitors provide comfortable viewing with versatile screen height/tilt/pivot/swivel adjustments. You can customize the display condition to create a more personal, comfortable workstation. The monitor can be easily assembled without any tools, and is also able to be wall-mounted.
  • Full HD IPS display
  • Integrated power module for organized workspaces
  • Personalized viewing angles and easy assembly
LG 27BK550Y - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/359341
Energy Class
Class F
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
23.8 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Black texture
62.22 cm x 24 cm x 40.16 cm
7.2 kg
Environmental Standards
TCO Certified Displays 9
Plug and Play, FCC Class B certified, UL, TUV GS, cUL, CB, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, REACH, EPA 7.0
Display Type
Energy Class
Class F
38 kWh
Diagonal Size
27"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
OSD Languages
German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean, UK English
Flicker Safe, Reader Mode, Factory Calibration, 6-axis colour adjustment, Smart Energy Saving technology, Color Calibrated, Mini PC attachable, Super Resolution+
Black texture
62.22 cm x 24 cm x 40.16 cm - with stand
7.2 kg
Audio
Speakers - stereo
Output Power / Channel
1.2 Watt
HDMI , DVI-D , VGA , Headphones , 2 x USB 2.0 downstream , USB 2.0 upstream , DisplayPort , Audio line-in
Mechanical
Tilt Angle
-5/+35
Swivel Angle
355
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), PVC free
1 x DVI cable , 1 x DisplayPort cable , 1 x audio cable , 1 x USB cable
MTBF
70,000 hour(s)
Input Voltage
23.8 W
23.8 kWh/1000h
Power Consumption (Typical)
27.4 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Without stand - width: 62.2 cm - depth: 5.84 cm - height: 37.15 cm - weight: 5.1 kg , With stand - width: 62.22 cm - depth: 24 cm - height: 40.16 cm - weight: 7.2 kg
Shipping Width
70.7 cm
Shipping Depth
55.6 cm
Shipping Height
18.6 cm
Shipping Weight
10 kg
Sustainability Information
TCO Certified
