LG 27 INCH Smart WebOS 23 Monitor FHD IPS HDMI
Quicklinx: HV8CWS00 Mfr#: 27SR50F-W.AEK
40 In Stock
£140.84 ex VAT
£169.00 inc VAT
LG MyView 27SR50F-W - LED monitor - Full HD (1080p) - 27" - HDR
LED-backlit LCD monitor - 27" - Smart monitor
Energy Class
Class E
USB Hub, Bluetooth adapter
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
HDR Capable
HDR10
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
2xHDMI
Display Position Adjustments
Tilt
Voltage
AC 100-240 V (50/60 Hz)
61.18 cm x 20.99 cm x 45.09 cm
5.6 kg
Display Type
LED-backlit LCD monitor / TFT active matrix - Smart monitor
Energy Class
Class E
Energy Class (HDR)
Class G
Diagonal Size
27"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
HDR Format
HDR10
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Auto Brightness Control, Flicker Safe, Smart Energy Saving technology, 8-bit(6-bit + FRC) Colour Depth, Screen Share, Dashboard, AI concierge
61.18 cm x 20.99 cm x 45.09 cm - with stand
5.6 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI , 2 x USB downstream
Mechanical
Tilt
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), AirPlay 2
Remote control
1 x HDMI cable - 1.5 m
Security Slot Type
Kensington security slot
Input Voltage
21 kWh/1000h
Power Consumption HDR (On mode)
24 kWh/1000h
Power Consumption (Typical)
25 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Included Software
ThinQ Home, WebOS 23
Dimensions & Weight Details
With stand - width: 61.18 cm - depth: 20.99 cm - height: 45.09 cm - weight: 5.6 kg , Without stand - width: 61.18 cm - depth: 4.51 cm - height: 37.09 cm - weight: 4.4 kg
Shipping Width
76.8 cm
Shipping Depth
12.6 cm
Shipping Height
43.5 cm
Shipping Weight
7.3 kg
Brand: LG
