LG 27" IPS Full HD Monitor
Quicklinx: HD1HWS00 Mfr#: 27MP400P-B.BEK
27'' IPS Full HD Monitor with 3-Side Virtually Borderless Design
True Color at Wide Angles
LG Monitor with IPS technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can view the screen at wide angles.
Immersive Experience
This display has slim bezel on three sides and doesn't interfere with dazzling precision, which allows you to create an optimized work environment through convenient tilt adjustment.
  • True color at wide angles
  • Immersive experience
  • Comfortable workplace
    Its convenient tilt adjustments with clean uni-body design allow you to create an optimized work environment.
  • Improved visual comfort
    To help lessen eye fatigue and provide eye comfort while reading documents on a monitor, Reader mode adjusts color temperature and luminance similar to reading a paper book.
  • Care for eyes
    Flicker Safe reduces invisible flickering on the screen, which helps reduce eye strain. It provides a comfortable working environment for a long time.
  • Fluid and rapid motion
    With AMD FreeSync technology, gamers can experience seamless, fluid movement in high-resolution and fast-paced games. It virtually reduces screen tearing and stuttering.
  • React faster to opponents
    Reduce input lag with Dynamic Action Sync so it helps gamers catch critical moments in real-time.
  • Attack first in dark
    Black Stabilizer helps gamers to avoid snipers hiding in the darkest places and quickly escape situations when the flash explodes.
  • Better aim
    Target point is fixed in the center to enhance shooting accuracy.
LG 27MP400P-B - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (VGA: 60 Hz, HDMI: 75 Hz)
Pixel Pitch
0.3113 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
AC 100-240 V (50/60 Hz)
61.2 cm x 19 cm x 45.49 cm
3.4 kg
Display Type
Energy Class
Class E
Diagonal Size
27"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3113 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Crosshair Display, Flicker Safe, Reader Mode, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Color Weakness Mode, Super Resolution+, 3-side virtually borderless design
61.2 cm x 19 cm x 45.49 cm - with stand
3.4 kg
HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
75 x 75 mm
Security lock slot (cable lock sold separately), detachable stand base
1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
21 kWh/1000h
Power Consumption (Typical)
22 Watt
Power Consumption (Max)
26 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
LG On-Screen Control
Dimensions & Weight Details
With stand - width: 61.2 cm - depth: 19 cm - height: 45.49 cm - weight: 3.4 kg , Without stand - width: 61.2 cm - depth: 5.62 cm - height: 36.25 cm - weight: 3.1 kg
0 - 80%
