LG 27"  Full HD IPS 100Hz HDMI Monitor
Quicklinx: HV5YWS00 Mfr#: 27MR400-B.AEKQ
More than 50 In Stock
£90.84 ex VAT
£109.00 inc VAT
The LG 27MR400-B monitor combines performance, versatility, and convenience in a sleek design. With its 27-inch Full HD display and LED backlight technology, it delivers exceptional clarity and color detail, making it suitable for both professional and leisure activities. The inclusion of AMD FreeSync technology ensures that gamers experience minimal input lag and screen tearing, providing a seamless and immersive gaming experience.
Viewing comfort is prioritized with features like Flicker Safe and Reader Mode, which help reduce eye strain during extended use. The monitor's adaptability is further enhanced by its wide viewing angles and tilt-adjustable stand, allowing users to find the perfect viewing position. Additionally, the LG 27MR400-B is equipped with essential connectivity options, including HDMI and VGA ports, to accommodate various devices and setups.
Whether for work, gaming, or watching movies, this monitor is designed to meet the needs of a wide range of users, offering both functionality and energy efficiency.
  • Enhanced visual clarity
    The 27-inch Full HD 1080p display, powered by LED backlight technology, offers vivid image clarity and a wide spectrum of 16.7 million colors, making every detail pop with life.
  • Seamless gaming experience
    With AMD FreeSync technology and a dynamic 100 Hz V-Sync rate, this monitor ensures smooth and uninterrupted gameplay, eliminating screen tearing and stuttering.
  • Optimal viewing comfort
    Features like Flicker Safe and Reader Mode reduce eye strain during long usage periods, while the tilt-adjustable stand allows for an ergonomic setup that suits any workspace.
  • Versatile connectivity
    Equipped with HDMI and VGA interfaces, this monitor offers multiple connection options for a wide range of devices, ensuring compatibility and convenience for users.
  • Advanced viewing modes
    Incorporating Black Stabilizer for enhanced dark scene visibility, Color Weakness Mode to assist those with color vision deficiency, and DAS Mode for reduced input lag, this monitor is designed to enhance every viewing experience.
LG 27MR400-B - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 100 Hz
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
1300:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
95% sRGB (CIE 1931), 99% sRGB (CIE 1931)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
AC 100-240 V (50/60 Hz)
61.17 cm x 20 cm x 45.61 cm
3.84 kg
Display Type
Energy Class
Class E
Diagonal Size
27"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
1300:1
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Flicker Safe, Reader Mode, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Color Weakness Mode, Super Resolution+, 3 Side Borderless Design, auto input switch
61.17 cm x 20 cm x 45.61 cm - with stand
3.84 kg
HDMI , VGA , Headphones (mini-jack)
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
Input Voltage
20 kWh/1000h
Power Consumption (Typical)
24 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
LG On-Screen Control
Dimensions & Weight Details
With stand - width: 61.17 cm - depth: 20 cm - height: 45.61 cm - weight: 3.84 kg , Without stand - width: 61.17 cm - depth: 5.05 cm - height: 36.23 cm - weight: 3.26 kg
Shipping Width
69 cm
Shipping Depth
14.3 cm
Shipping Height
44.8 cm
Shipping Weight
5.3 kg
Brand: LG
