This monitor features an Infinity display that provides a borderless visual experience for 4-side of the display for an all-inclusive view. Smoothness and solidness coexist in the curved structure - the beauty of ArcLine is the icing on the cake.
Infinity display
The Infinity display provides a borderless visual experience for 4-side of the display for an all-inclusive view. -
ArcLine stand
Smoothness and solidness coexist in the curved structure - the beauty of ArcLine is the icing on the cake. -
Enjoy outstanding color expression
The LG IPS monitor provides an accurate color and low-color shift. It delivers realistic color expression. -
Protect your eyes and view in comfort
Over time, working, gaming and movie viewing can cause eye strain and fatigue. But, this display features technologies that help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level. -
Customize your workspace for multitasking
Screen Split divides the display into multiple sections for different tasks by resizing the windows on the screen. With PIP mode you can work on the main screen while watching a video in a smaller window floating on the screen. -
Offers improved color vision to color weakness
Color revision algorithms are used to help those with color weakness who have difficulty distinguishing certain ranges of colors can view all the important content.
- LG 24MP88HV - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/356599
- Energy Class
- Class E
- Energy Consumption per Year
- 28 kWh
- Power Consumption (On mode)
- 17.8 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- 2xHDMI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Silver spray with white back
- 54.1 cm x 18.62 cm x 41.45 cm
- 3.2 kg
- Plug and Play, FCC Class B certified, TUV, DDC/CI, ERP, EPA 6.0
- Display Type
- Energy Class
- Class E
- 28 kWh
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Picture in picture, split screen, Picture Mode, SUPER Energy Saving Technology, Flicker Safe, Reader Mode, SIX Axis Control, MaxxAudio, Smart Energy Saving technology, Color Calibrated, Black Stabilizer, My Display Preset, Color Weakness Mode, Mega DFC, 99% sRGB colour gamut
- 54.1 cm x 18.62 cm x 41.45 cm - with stand
- 3.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- VGA , 2 x HDMI , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -2/+15
- VESA Mounting Interface
- 75 x 75 mm
- 17.8 W
- Power Consumption SDR (On mode)
- 17.8 kWh/1000h
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- OS Required
- Windows 10
- Dimensions & Weight Details
- With stand - width: 54.1 cm - depth: 18.62 cm - height: 41.45 cm - weight: 3.2 kg , Without stand - width: 54.1 cm - depth: 4.66 cm - height: 31.33 cm - weight: 2.9 kg
