LG 24BK550Y 24" 1920x1080 5ms VGA DVI HDMI DisplayPort LED Monitor
Quicklinx: DN95WS00 Mfr#: 24BK550Y
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
21 in stock
£126.52 ex VAT
£151.82 inc VAT
FULL HD IPS DISPLAY
Designed for professionals, this Full HD display with IPS technology minimizes color shifts and provides outstanding picture quality from virtually any viewing angle.
INTEGRATED POWER MODULE FOR ORGANIZED WORKSPACES
The power module is integrated with the monitor, helping to reduce the amount of power modules in your workspace.
PERSONALIZED VIEWING ANGLES AND EASY ASSEMBLY
The monitors provide comfortable viewing with versatile screen height/tilt/pivot/swivel adjustments. You can customize the display condition to create a more personal, comfortable workstation. The monitor can be easily assembled without any tools, and is also able to be wall-mounted (Wall mount sold separately).
MINI PC MOUNTING CAPABILITIES
The BK550 is designed to allow for the discreet mounting of compatible mini PCs on the rear. Using an Intel NUC or 100x100mm wall mount, users can easily mount their mini PC (Bracket and PC sold separately).
LG 24BK550Y-B - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
22 W
USB 2.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Environmental Standards
ENERGY STAR Qualified
CSA, UL, TUV, TUV GS, NEMKO, SEMKO, EMC 2004/108/EC, EN55022:2006, DIN ISO 9241-307, TCO Displays 7.0, EPA 7.0
3-year warranty
Display Type
Energy Class
Class A
31 kWh
22 W
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 2.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
On-screen Digital Controls, Flicker Safe, Reader Mode, SIX Axis Control, Mercury free, Smart Energy Saving technology
Audio
Speakers - stereo
Output Power / Channel
1.2 Watt
HDMI , DVI-D (HDCP) , VGA , Headphones , 2 x USB 2.0 downstream , USB 2.0 upstream , DisplayPort
Mechanical
Tilt Angle
-5/+35
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Cable holder
1 x DisplayPort cable , 1 x USB cable , 1 x audio cable
MTBF
70,000 hour(s)
ENERGY STAR Certified
Limited warranty - 3 years
LG 24BK550Y 24 Bundle deal on LG 24BK550Y 24" 1920x1080 5ms VGA DVI HDMI DisplayPort LED Monitor
£225.69
Diagonal Size: 24in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: LG
Price Range Ex VAT: 100 - 150
