Full HD IPS Display
High Definition with Accurate Colour
1080p Full HD resolution with IPS delivers brilliant images that pop with vibrant detail from any viewing angle.
AMD FreeSync™
Clearer, Smoother Image
AMD FreeSync™ Technology and a dynamic refresh rate
Dynamic Action Sync
React Faster to The Action
Dynamic Action Sync mode allows you to instantly react to your opponents and attack them without any display lag. It synchronizes your senses with real-time scenes in fast-paced games by minimizing input lag.e of 75Hz virtually eliminates screen tearing and stuttering to bring you seamless, fluid movement during high-res, fast-paced games.
High definition with accurate color
1080p Full HD resolution with IPS delivers brilliant images that pop with vibrant detail from any viewing angle. -
Clearer, smoother image
AMD FreeSync technology and a dynamic refresh rate of 75 Hz virtually eliminates screen tearing and stuttering to bring you seamless, fluid movement during high-res, fast-paced games. -
React faster to the action
Dynamic Action Sync mode allows you to instantly react to your opponents and attack them without any display lag. It synchronizes your senses with real-time scenes in fast-paced games by minimizing input lag. -
Enemies have nowhere to hide
Black Stabilizer gives you full visual clarity, even in games where you spend a lot of time in the dark. It synchronizes and brightens the darkest areas, so that you can find enemies hiding in the shadows and shoot first. -
Easier user interface
OnScreen Control is simple and intuitive. You can customize your display options with a few simple clicks. -
Convenient and flexible
Mount the monitor to suit your work or entertainment set up.
- LG 24MK43HP-B - LCD monitor - Full HD (1080p) - 23.8"
- LCD monitor - 23.8"
- Energy Class
- Class E
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 (VGA: 60 Hz, HDMI: 75 Hz)
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931)
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- Matte black
- 55.5 cm x 18.19 cm x 42.2 cm
- 3.1 kg
- FCC Class B certified, VCCI, cUL, CCC, KC, ERP, TUV-TYPE
- Display Type
- LCD monitor / TFT active matrix
- Energy Class
- Class E
- Diagonal Size
- 23.8"
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72% (CIE 1931)
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- OSD Languages
- Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
- Digital Fine Contrast ratio (DFC), Crosshair Display, Flicker Safe, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, Colour Temperature Selection, Super Resolution+, Black Level, gamma correction
- Matte black
- 55.5 cm x 18.19 cm x 42.2 cm - with stand
- 3.1 kg
- HDMI (HDCP 1.4) , VGA , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/20
- Cables Included
- HDMI cable
- Input Voltage
- Power Consumption SDR (On mode)
- 18 kWh/1000h
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- Included Software
- LG On-Screen Control
- Dimensions & Weight Details
- With stand - width: 55.5 cm - depth: 18.19 cm - height: 42.2 cm - weight: 3.1 kg , Without stand - width: 55 cm - depth: 3.84 cm - height: 33.09 cm - weight: 2.8 kg
- Shipping Width
- 68.8 cm
- Shipping Depth
- 39 cm
- Shipping Height
- 12.4 cm
- Shipping Weight
- 4.2 kg
