LG 23MP68VQ 23" 1920x1080 5ms VGA DVI-D HDMI IPS LED Monitor
Quicklinx: DMYSWS00 Mfr#: 23MP68VQ
The LG IPS monitor provides an accurate color and low color shift. Its realistic color expression is ensured with sRGB over 99% of the color space and color calibration tested before the monitors are delivered to the customer. The coexistence of smoothness and solidness in the curved structure. The beauty of ArcLine is the icing on the cake.
  • Enjoy outstanding color expression
  • ArcLine stand
  • Enjoy smoother game play
    MP68 especially adapted to AMD FreeSync technology which eliminates tearing from the low frame rate and also screen stuttering as connecting HDMI port. All of these bring that you can enjoy and immerse in game play.
  • Immerse yourself in the game
    The Black Stabilizer allows you to have better visibility, even in dark scenes.
  • Protect your eyes and view inComfort
    Did you know that your eyes are affected by flickers on the monitor while you may not have seen them? Over time, working, gaming and movie viewing can cause eye strain and fatigue. But, Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
  • Offers improved color vision to color weakness
    Color revision algorithms are used to help those with color weakness who have difficulty distinguishing certain ranges of colors can view all the important content.
LG 23MP68VQ - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A+
Energy Consumption per Year
25 kWh
Power Consumption (On mode)
17 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
52.39 cm x 18.68 cm x 40.61 cm
3.1 kg
Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, ERP, EPA 6.0
Display Type
Energy Class
Class A+
25 kWh
Diagonal Size
23"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, SUPER Energy Saving Technology, SUPER + Resolution, Auto Resolution, Flicker Free technology, 4-screen split, Reader Mode, 6-axis colour adjustment, Color Wizard, Response Time Control, Color Weakness Mode, Mega DFC
52.39 cm x 18.68 cm x 40.61 cm - with stand
3.1 kg
HDMI , DVI-D , VGA , Headphones
Mechanical
Tilt
Tilt Angle
-2/+15
VESA Mounting Interface
75 x 75 mm
Key lock
Input Voltage
AC 120/230 V
17 W
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 52.39 cm - depth: 18.68 cm - height: 40.61 cm - weight: 3.1 kg , Without stand - width: 52.39 cm - depth: 9.17 cm - height: 31.17 cm - weight: 2.7 kg
