The LG 24MR400-B monitor is designed to elevate your viewing and gaming experience. With its 24-inch Full HD display, you'll enjoy vivid colors and clear images, thanks to the LED backlight technology and support for 16.7 million colors. The wide 178-degree viewing angles ensure that the picture remains consistent from virtually any position.
Gamers will appreciate the smooth, seamless gameplay enabled by AMD FreeSync technology and a 100 Hz refresh rate, which work together to eliminate screen tearing and stuttering. The monitor's quick 5 ms response time ensures that fast-moving scenes are rendered with clarity. Additionally, features like Black Stabilizer offer enhanced visibility in dark scenes, while the Dynamic Action Sync (DAS) Mode minimizes input lag, making every action more instantaneous.
For those long hours in front of the screen, the LG 24MR400-B has been thoughtfully designed with eye comfort in mind. Flicker Safe technology and Reader Mode help to reduce eye strain, while the tilt-adjustable stand allows for an optimal viewing angle, enhancing both comfort and productivity. Whether for work or play, this monitor is equipped to deliver an exceptional performance.
Enhanced visual experience
The LG 24MR400-B monitor delivers a stunning visual experience with its 24-inch Full HD display, powered by LED backlight technology. The vibrant 16.7 million colors and wide 178-degree viewing angles ensure a vivid and consistent image from virtually any perspective. -
Seamless gameplay
Equipped with AMD FreeSync technology and a dynamic 100 Hz refresh rate, this monitor offers smooth and seamless gameplay, reducing screen tearing and stuttering. The quick 5 ms response time further enhances the gaming experience, making fast-paced action look crisp and clear. -
Comfortable viewing
With features like Flicker Safe and Reader Mode, the LG 24MR400-B monitor reduces eye strain during long usage sessions. The tilt-adjustable stand allows for an optimal viewing angle, ensuring comfort and better productivity. -
Optimized for performance
The monitor boasts several features designed to enhance user experience, including Black Stabilizer for better visibility in dark scenes, Color Weakness Mode to assist those with color vision deficiency, and Dynamic Action Sync (DAS) Mode to minimize input lag.
- LG 24MR400-B - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class E
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 100 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1300:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 95% sRGB (CIE 1931), 99% sRGB (CIE 1931)
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 100-240 V (50/60 Hz)
- 54 cm x 20 cm x 41.4 cm
- 2.75 kg
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1300:1
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Flicker Safe, Reader Mode, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Color Weakness Mode, Super Resolution+, 3 Side Borderless Design, auto input switch
- 54 cm x 20 cm x 41.4 cm - with stand
- 2.75 kg
- HDMI , VGA , Headphones (mini-jack)
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable
- Input Voltage
- Power Consumption SDR (On mode)
- 15 kWh/1000h
- Power Consumption (Typical)
- 17 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- Included Software
- LG On-Screen Control
- Dimensions & Weight Details
- With stand - width: 54 cm - depth: 20 cm - height: 41.4 cm - weight: 2.75 kg , Without stand - width: 54 cm - depth: 5.05 cm - height: 32.06 cm - weight: 2.34 kg
- Shipping Width
- 61.3 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 40 cm
- Shipping Weight
- 4.08 kg
