QUAD CORE SOC
The High Performance SoC can execute several tasks at the same time and provides smooth content playback.
WEBOS 2.0
The webOS 2.0 platform provides easy and convenient tools to create content. LG’s SDK and technical support make content development and management easier.
SIMPLE INSTALLATION
Installation has been simplified by removing the external media player and Ethernet/RS232C cables.
SOFTAP
The 22SM3B with SoftAP software can operate as a wireless access point for mobile devices.
BEACON
With BEACON and Bluetooth Low Energy (BLE) supported by 22SM3B, retail stores can provide coupons and information in real-time.
Quad core SoC
The high performance SoC can execute several tasks at the same time and provides smooth content playback. -
Mirroring
Content sharing is more convenient on a Wi-Fi network. -
SoftAP
SoftAP software enables a TV to operate as a wireless access point for mobile devices.
- LG 22SM3B-B - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Input Connectors
- HDMI, VGA
- Built-in Ethernet
- Dimensions (WxDxH) - without stand
- 51 cm x 5.38 cm x 30.21 cm
- 3.6 kg
- Display Type
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Backlight Technology
- LED backlight
- 51 cm x 5.38 cm x 30.21 cm - without stand
- 3.6 kg
- HDMI (HDCP) , RGB (HD-15) , Audio line-in , RS-232C , Network (RJ-45) , USB 3.0
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x RJ-11 to RS-232 adapter
