LG 22MK600M-B 22" 1920x1080 5ms VGA HDMI IPS LED Monitor
Quicklinx: DRZ2WS00 Mfr#: 22MK600M-B
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: HDMI, VGA (HD-15)
13 in stock
£91.14 ex VAT
£109.36 inc VAT
IPS technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can view the screen at virtually any angle.
This streamlined display features a slim bezel on three sides for an immersive visual experience and no distraction from the dazzlingly precise, lifelike image.
With Radeon FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. Radeon FreeSync virtually eliminates screen tearing and stuttering.
  • High Definition with True Color
  • Immersive visual experience
  • Clearer, smoother image
  • React faster to the action
    Minimize input lag with Dynamic Action Sync so you can catch every single moment in real-time.
  • Enemies have nowhere to hide
    You can avoid snipers hiding in the darkest places and quickly escape situations when the flash explodes.
  • Better aim
    Target point is fixed in the center to enhance shooting accuracy.
  • Perfect eyes with Reader Mode
    Reducing blue light to help lessen eye fatigue, Reader Mode provides optimal condition for reading. With easy joystick control, you can more comfortably read your monitor screen.
  • Offers stable image
    Reducing the flicker level to almost zero, Flicker-Safe helps you protect your eyes from exhausting flickers.
  • Easier user interface
    OnScreen Control is simple and intuitive. You can customize your display options with a few simple clicks.
  • Convenient and flexible
    This monitor gives you the freedom to take it off the desk and hang it on the wall. Liberate your viewing options and save desktop space with this wall-mountable LG monitor.
LG 22MK600M-B - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A+
Energy Consumption per Year
23 kWh
Power Consumption (On mode)
16 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.2479 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Matte black
48.87 cm x 18.2 cm x 38.67 cm
2.7 kg
Plug and Play, FCC Class B certified, TUV, SEMKO, DDC/CI, IEC 62087 Edition 2
Display Type
Energy Class
Class A+
23 kWh
16 W
Diagonal Size
22"
Viewable Size
21.5"
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2479 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean, UK English
4:3 in Wide, Mega Contrast, On-screen Digital Controls, Crosshair Display, Flicker Safe, Reader Mode, Mercury free, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), FreeSync Technology, Mega DFC, frameless bezel design
Matte black
48.87 cm x 18.2 cm x 38.67 cm - with stand
2.7 kg
2 x HDMI (HDCP) , VGA , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
75 x 75 mm
Cable holder
1 x HDMI cable - 1.8 m , 1 x VGA cable
Security Slot Type
Kensington security slot
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 48.87 cm - depth: 18.2 cm - height: 38.67 cm - weight: 2.7 kg , Without stand - width: 48.87 cm - depth: 6.68 cm - height: 29.3 cm - weight: 2.3 kg
Shipping Width
56.1 cm
Shipping Depth
36.3 cm
Shipping Height
13.9 cm
Shipping Weight
3.7 kg
LG 22MK600M-B 22 Bundle deal on LG 22MK600M-B 22" 1920x1080 5ms VGA HDMI IPS LED Monitor
£190.31
Diagonal Size: 22in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: LG
Price Range Ex VAT: 50 - 100
