IPS technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can view the screen at virtually any angle.
This streamlined display features a slim bezel on three sides for an immersive visual experience and no distraction from the dazzlingly precise, lifelike image.
With Radeon FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. Radeon FreeSync virtually eliminates screen tearing and stuttering.
High Definition with True Color
IPS technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can view the screen at virtually any angle. -
Immersive visual experience
This streamlined display features a slim bezel on three sides for an immersive visual experience and no distraction from the dazzlingly precise, lifelike image. -
Clearer, smoother image
With Radeon FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. Radeon FreeSync virtually eliminates screen tearing and stuttering. -
React faster to the action
Minimize input lag with Dynamic Action Sync so you can catch every single moment in real-time. -
Enemies have nowhere to hide
You can avoid snipers hiding in the darkest places and quickly escape situations when the flash explodes. -
Better aim
Target point is fixed in the center to enhance shooting accuracy. -
Perfect eyes with Reader Mode
Reducing blue light to help lessen eye fatigue, Reader Mode provides optimal condition for reading. With easy joystick control, you can more comfortably read your monitor screen. -
Offers stable image
Reducing the flicker level to almost zero, Flicker-Safe helps you protect your eyes from exhausting flickers. -
Easier user interface
OnScreen Control is simple and intuitive. You can customize your display options with a few simple clicks. -
Convenient and flexible
This monitor gives you the freedom to take it off the desk and hang it on the wall. Liberate your viewing options and save desktop space with this wall-mountable LG monitor.
- LG 22MK600M-B - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class A+
- Energy Consumption per Year
- 23 kWh
- Power Consumption (On mode)
- 16 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.2479 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Matte black
- 48.87 cm x 18.2 cm x 38.67 cm
- 2.7 kg
- Plug and Play, FCC Class B certified, TUV, SEMKO, DDC/CI, IEC 62087 Edition 2
- Display Type
- Energy Class
- Class A+
- 23 kWh
- 16 W
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- AMD FreeSync
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2479 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean, UK English
- 4:3 in Wide, Mega Contrast, On-screen Digital Controls, Crosshair Display, Flicker Safe, Reader Mode, Mercury free, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Mega DFC, frameless bezel design
- Matte black
- 48.87 cm x 18.2 cm x 38.67 cm - with stand
- 2.7 kg
- 2 x HDMI (HDCP) , VGA , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 75 x 75 mm
- Included Accessories
- Cable holder
- Cables Included
- 1 x HDMI cable - 1.8 m
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 48.87 cm - depth: 18.2 cm - height: 38.67 cm - weight: 2.7 kg , Without stand - width: 48.87 cm - depth: 6.68 cm - height: 29.3 cm - weight: 2.3 kg
- Shipping Width
- 56.1 cm
- Shipping Depth
- 36.3 cm
- Shipping Height
- 13.9 cm
- Shipping Weight
- 3.7 kg
