LG 22M35A-B 22" 1920x1080 5ms VGA LED Black Monitor
Quicklinx: 9D4SWS00 Mfr#: 22M35A-B
Brilliant LED backlighting display delivers crystal-clear images, true blacks and the most vivid, life-like colors on a slim screen. Fast response time of 5 ms allows the smooth viewing of action scenes, sports and video games with greater clarity and vivid quality. The consistent response time also allows you to watch videos or play games for a longer time while minimizing eye strain.
  • LED monitor
  • Fast response time
  • Reader mode
    Reducing blue light to protect your eyes, reader mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for long.
  • Super energy saving
    LG super energy saving technology has been upgraded so that the additional energy saved besides the effect of the LED backlight has improved from 25% to 30%.
  • Flicker-safe
    Dimming technology is applied to minimize the flicker level causing eye fatigue. With almost-zero flicker technology, you'll be able to watch longer, comfortably.
  • Dual smart solution
    This solution allows simple set up of dual monitor, dual taskbar and dual web.
LG 22M35A-B - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
50.9 cm x 21.5 cm x 41.1 cm
2.6 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI
Display Type
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Screen Coating
Backlight Technology
LED backlight
Picture Mode, SUPER Energy Saving Technology, Auto Resolution, integrated cable management, Dual Smart Solution
50.9 cm x 21.5 cm x 41.1 cm - with stand
2.6 kg
VGA
Mechanical
Tilt
Tilt Angle
-3/+20
Power Supply
Internal
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 50.9 cm - depth: 21.5 cm - height: 41.1 cm - weight: 2.6 kg , Without stand - width: 50.9 cm - depth: 9.8 cm - height: 31.6 cm - weight: 2.2 kg
Sustainability Information
ENERGY STAR Certified
