21.45" Full HD Display
Vibrant and Accurate Color
LG Monitor highlights the performance of liquid crystal displays. The 21.45-inch screen with Full HD (1920X1080) display delivers precise and clear imagery through outstanding color accuracy.
Flicker Safe
Care for Eyes
Flicker Safe reduces invisible flickering on the screen, which helps reduce eye strain. It provides a comfortable working environment for a long time.
OnScreen Control
Easier User Interface
You can customize the workspace by splitting the display or adjusting basic monitor options with just a few mouse clicks.
AMD FreeSync™
Fluid and Rapid Motion
With AMD FreeSync™ technology, gamers can experience seamless, fluid movement in high resolution and fast-paced games. It virtually reduces screen tearing and stuttering.
Dynamic Action Sync
React Faster to Opponents
Reduce input lag with Dynamic Action Sync so it helps gamers catch critical moments in real-time.
Black Stabilizer
Attack First in Dark
Black Stabilizer helps gamers to avoid snipers hiding in the darkest places and quickly escape situations when the flash explodes.
Vibrant and accurate color
LG monitor highlights the performance of liquid crystal displays. The 21.45-inch screen with Full HD (1920 x 1080) display delivers precise and clear imagery through outstanding color accuracy. -
Improved visual comfort
To help lessen eye fatigue and provide eye comfort while reading documents on a monitor, Reader mode adjusts color temperature and luminance similar to reading a paper book. -
Care for eyes
Flicker Safe reduces invisible flickering on the screen, which helps reduce eye strain. It provides a comfortable working environment for a long time. -
Easier user interface
You can customize the workspace by splitting the display or adjusting basic monitor options with just a few mouse clicks. -
Comfortable workplace
Its convenient tilt adjustments with clean uni-body design allow you to create an optimized work environment. -
Fluid and rapid motion
With AMD FreeSync technology, gamers can experience seamless, fluid movement in high resolution and fast-paced games. It virtually reduces screen tearing and stuttering. -
React faster to opponents
Reduce input lag with Dynamic Action Sync so it helps gamers catch critical moments in real-time. -
Attack first in dark
Black Stabilizer helps gamers to avoid snipers hiding in the darkest places and quickly escape situations when the flash explodes. -
Better aim
Target point is fixed in the center to enhance shooting accuracy.
- LG 22MP410P-B - LED monitor - Full HD (1080p) - 21.45"
- LED-backlit LCD monitor - 21.45"
- Energy Class
- Class E
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 (VGA: 60 Hz, HDMI: 75 Hz)
- Pixel Pitch
- 0.24825 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC (CIE 1931)
- Input Connectors
- HDMI, VGA
- Tilt
- 51.16 cm x 19 cm x 38.35 cm
- 2.6 kg
- 2-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 21.45"
- Viewable Size
- 21"
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.24825 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Crosshair Display, Flicker Safe, Reader Mode, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Color Weakness Mode, Super Resolution+, ergonomic stand
- 51.16 cm x 19 cm x 38.35 cm - with stand
- 2.6 kg
- HDMI , VGA
Mechanical
- Tilt
- VESA Mounting Interface
- 75 x 75 mm
- Cables Included
- 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Power Consumption SDR (On mode)
- 15 kWh/1000h
- Power Consumption (Typical)
- 19 Watt
- Power Consumption (Max)
- 22 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- Included Software
- LG On-Screen Control
- 2-year warranty
