An immersive work environment is ensured through realistic color expression thanks to sRGB over 99 percent and the IPS display.
The coexistence of smoothness and solidness in the curved structure. The beauty of ArcLine is the icing on the cake.
Flicker safe and reader mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
Enjoy outstanding color expression
An immersive work environment is ensured through realistic color expression thanks to sRGB over 99 percent and the IPS display. -
ArcLine stand
The coexistence of smoothness and solidness in the curved structure. The beauty of ArcLine is the icing on the cake. -
Protect your eyes and view in comfort
- LG 22MP68VQ - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class A
- Energy Consumption per Year
- 24 kWh
- Power Consumption (On mode)
- 16 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.25 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V
- 49.12 cm x 18.68 cm x 38.77 cm
- 2.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, ERP
- Display Type
- Energy Class
- Class A
- 24 kWh
- Diagonal Size
- 22"
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.25 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Power off timer, HDCP, SUPER Energy Saving Technology, SUPER + Resolution, game mode, Cinema Mode, On-screen Digital Controls, Flicker Free technology, 4-screen split, Reader Mode, 6-axis colour adjustment, Color Wizard, Black Stabilizer, Response Time Control, Intelligent Auto, Color Weakness Mode, Mega DFC, Original ratio
- 49.12 cm x 18.68 cm x 38.77 cm - with stand
- 2.8 kg
- HDMI , DVI-D , VGA , Headphones
Mechanical
- Tilt
- Tilt Angle
- -2/+15
- VESA Mounting Interface
- 75 x 75 mm
- Key lock
- Cables Included
- 1 x VGA cable
- Input Voltage
- AC 120/230 V
- 16 W
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 49.12 cm - depth: 18.68 cm - height: 38.77 cm - weight: 2.8 kg , Without stand - width: 49.12 cm - depth: 9.17 cm - height: 29.33 cm - weight: 2.4 kg
Sustainability Information
- ENERGY STAR Certified
