Lexmark X864de Mono A3 Laser All-In-One
Quicklinx: 6JT5WS00 Mfr#: 19Z0256
Built for your most demanding document needs, these powerful multifunction devices support media sizes up to A3 and deliver A4 print and copy speeds as fast as 55 pages per minute. You'll benefit from flexible paper handling, advanced finishing options, leading-edge security and the simplicity of Lexmark's user-friendly e-Task color touch screen. Best of all, the Lexmark X864de 4 is solutions-ready. Gain real momentum by adding application solutions tailored to the way you work!
  • 4-in-1 with Dominating Speed, Up to A3
    Built for your most demanding document needs, this powerful multifunction device supports media sizes up to A3 and delivers print and copy speeds as fast as 55 pages per minute. Don't need fax? Consider the Lexmark X864de 3.
  • Gain Real Momentum
    The Lexmark X864de 4 monochrome laser MFP with fax is the top of the X860 Series, providing fax, automatic duplexing and standard input capacity for up to 1,100 sheets, expandable to 5,100 sheets with optional paper handling accessories.
  • Enormously Intuitive Touch Screen
    Lexmark's award-winning 22.9 cm (9 inch) colour e-Task touch screen gives you fast, easy access to document capture and workflow functions. Tailor it to your business requirements with the icons and shortcuts you need most.
  • Optional Finishing
    Save time, money and office space by eliminating pre-printed documents and producing more of your print jobs on demand and in-house. Finishing options include stapling, hole punching (2/4 holes), offset stacking and booklet folding with overlap adjustment.
  • State-of-the-art Security
    Protects you from risk with state-of-the-art features for secure management, network communication and information storage. What's more, customisable user-access controls let you enable or disable functions with ease.
  • Solutions-Ready
    Includes Lexmark's award-winning solutions platform for running tailored applications and workflow solutions, such as Lexmark Print Release and Document Accounting. Contact your Lexmark representative to learn more.
Lexmark X864de 4 - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
300000 impressions
Max Copying Speed
Up to 55 ppm
Max Printing Speed
Up to 55 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi (600 x 300 dpi colour)
Display
9"
Original Size
A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets, books
Document Feeder Capacity
75 sheets
Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity
1100 sheets
Max Media Capacity
5100 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Collator
Optional
Stacker
Optional
Stapler
Optional
Binder
Optional
Automatic Duplexing
Yes (copying)
Connection Availability
USB 2.0, Gigabit LAN, USB host
64.1 cm x 70.5 cm x 80.3 cm
76.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
300000 impressions
Display Diagonal Size
9"
Display Features
Touch screen
Standard Memory
256 MB 256 MB
Max Supported Memory
1280 MB 1.25 GB
Copying
Max Copying Speed
Up to 55 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Automatic Duplexing
Copying Features
ID Card Copy
Printing
Max Printing Speed
Up to 55 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PPDS, XPS, PDF 1.6
Image Enhancement Technology
2400 IQ
First Print Out Time B/W
6.5 sec
Scanning
Optical Resolution
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Document & Media Handling
Max Original Size
Original Type
Sheets, books
75 sheets
Max Media Size
A3/Ledger
Supported Media Type
1100 sheets
Max Media Capacity
5100 sheets
100 sheets
500 sheets
ADF - 75 sheets - A3/Ledger (297 x 432 mm) , Bypass tray - 100 sheets - A3/Ledger (297 x 432 mm) , 2 x input tray - 500 sheets - A3/Ledger (297 x 432 mm) , Output tray - 500 sheets - A3/Ledger (297 x 432 mm)
Speed Details
Printing: up to 55 ppm (A4) - B/W , Printing: up to 28 ppm (A3) - B/W , Printing: up to 50 ppm (A4) - B/W duplex , Printing: up to 18 ppm (A3) - B/W duplex , Copying: up to 55 ppm (A4) - B/W , Copying: up to 28 ppm (A3) - B/W , Copying: up to 50 ppm (A4) - B/W duplex , Copying: up to 18 ppm (A3) - B/W duplex , Scanning: up to 55 ppm (A4) - B/W , Scanning: up to 27 ppm (A4) - colour , Scanning: up to 50 ppm (A4) - B/W duplex , Scanning: up to 18 ppm (A4) - colour duplex
Finishing Equipment
Collator
Optional
Stacker
Optional
Stapler
Optional
Binder
Optional
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Network Protocols
TCP/IP, IPX/SPX, AppleTalk, DLC/LLC, IPP, LPR/LPD, RAW IP (Port 9100)
Security Protocols & Features
LDAP, SSL, NDS Authentication over IP, Apple Bonjour, LEAP, SMB authentication, TLS, IPsec, 802.1x
Operating System Support
MS Windows XP, MS Windows 2000, Apple Mac OS X, Novell NetWare 5.x, MS Windows Server 2003, Apple Mac OS 9.x, MS Windows Server 2008 x64 Edition, IBM AIX 5.2, Sun Solaris 8, Sun Solaris 9, IBM OS/400, Red Hat Enterprise Linux WS 3.0, Red Hat Enterprise Linux WS 4.0, MS Windows 7, Linux Linpus Desktop 9.2, Linux Linpus Desktop 9.3, Red Hat Enterprise Linux WS 5.0, SuSE Linux Enterprise Server 8.0, SuSE Linux Enterprise Server 9.0, SuSE Linux Enterprise Server 10, SuSE Linux Enterprise Server 11, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, openSUSE 10.2, openSUSE 10.3, openSUSE 11.0, openSUSE 11.1, Linux Linspire 6.0, Debian GNU/Linux 4.0, Debian GNU/Linux 5.0, Red Flag Linux Desktop 5.0, Red Flag Linux Desktop 6.0, Ubuntu Linux 7.10, Ubuntu Linux 8.04 LTS, Ubuntu Linux 8.10, Ubuntu Linux 9.04, HP-UX 11.11, HP-UX 11.23, HP-UX 11.31, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), Sun Solaris 10, MS Windows Server 2008, Novell NetWare 6.x, IBM AIX 5.3, SunSoft Solaris x86 10, IBM AIX 6.1
Software Included
Drivers & Utilities
First Copy Out Time B/W
7 sec
Consumables Included
1 x toner cartridge (black) - up to 35000 pages , 1 x drum - up to 70000 pages
FCC Class A certified, CSA, TUV GS, CISPR 22 Class A, BSMI CNS 13438 Class A, EN 61000-3-2, EN55022, SEMKO, VCCI Class A ITE, EN 61000-3-3, EN55024, IEC 60320-1, CB, CCC, PSB, MIC, ICES-003 Class A, EK, UL 60950-1, IEC 60950-1, EN 60950-1, TUV Rh, C-Tick Class A, Nemko N-mark, UL-AR
ENERGY STAR Certified
Limited warranty - 1 year - on-site
64.1 cm
70.5 cm
80.3 cm
76.7 kg
Shipping Width
88 cm
Shipping Depth
85 cm
Shipping Height
94 cm
Sound Emission
30 dBA (idle) / 53 dBA (operating)
16 °C
32 °C
8 - 80%
