Lexmark X656dte MFP/mono 53ppm A4 fax
Quicklinx: 6JJVWS00 Mfr#: 16M1652
The Lexmark X656dte packs more benefits than ever into a high-performance, space-saving multifunction laser. Power up your workgroup with reliable, ultra-fast printing and copying. Boost productivity with superior colour-scanning capabilities and efficient workflow solutions. And experience smart, new ways to lower costs while reducing the environmental impact of printing. What’s more, you’ll benefit from a second input drawer to boost your total capacity.
Up to 53 ppm, as fast as 9.5 seconds to first page.
Automatic document feeder holds up to 75 sheets and scans both sides of your document in one pass.
Extra-large 9” colour touch screen.
Recommended monthly volume: 5000 to 30000 pages.
Ships with an 18,000-page Return Program Print Cartridge.
Lexmark Extra High Yield Print Cartridges available (36000 pages).
80GB hard disk for expanded functionality.
Added 550-sheet drawer for 1,200-sheet total input capacity.
  • An Output Hero
    Robust and reliable for advanced performance and incredible 53 ppm output speed. Includes an additional 550-sheet input drawer for 1,200-sheets of total standard input capacity, with options available to load up to 3,200 sheets. Upping the functionality factor – a built-in solutions framework and hard disk provided standard.
  • A Large-Impact Touch Screen
    The extra large 9-inch (22.9 cm) colour touch screen is command central and can be tailored with the apps and shortcuts you need most.
  • Personalised User Settings
    MyMFP feature lets multiple users save and re-access their personal copy/scan settings and address book on a simple flash drive-even their own touch screen configuration.
  • Less Work for the Help Desk
    Network-ready and very easy to set up, plus Universal Driver support for simple multiple deployment. Also includes free MarkVision Enterprise software for time-saving remote management. Ships with an 18,000-page print cartridge and offers a 36,000-page cartridge at replacement time. (Average standard yield, ISO/IEC 19752)
  • Get Efficient with Solution Apps
    Opt for one of Lexmark's leading workflow-enhancing applications to help you lower costs, analyze usage data, expand your functionality, and move information more securely. Just call a Lexmark representative to get started.
Lexmark X656dte MFP - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
275000 impressions
Max Copying Speed
Up to 53 ppm
Max Printing Speed
Up to 53 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Original Size
216 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
75 sheets
Media Size
216 x 356 mm (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity
1200 sheets
Max Media Capacity
3200 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying)
Connection Availability
USB 2.0, LAN, USB host
54.8 cm x 61.1 cm x 88.5 cm
45.4 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
275000 impressions
Standard Memory
256 MB 256 MB
Max Supported Memory
1280 MB 1.25 GB
Copying
Max Copying Speed
Up to 53 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Automatic Duplexing
Printing
Max Printing Speed
Up to 53 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PPDS
Image Enhancement Technology
1200 IQ, 2400 IQ
First Print Out Time B/W
9.5 sec
Scanning
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
PC Faxing
Document & Media Handling
Max Original Size
216 x 356 mm
Original Type
Sheets
75 sheets
Max Media Size
Other
Supported Media Type
1200 sheets
Max Media Capacity
3200 sheets
100 sheets
500 sheets
2 x input tray - 550 sheets , Bypass tray - 100 sheets , Output tray - 550 sheets
Speed Details
Printing: up to 53 ppm (A4) - B/W , Printing: up to 55 ppm (Letter A) - B/W , Printing: up to 36 ppm (A4) - B/W duplex , Printing: up to 37 ppm (Letter A) - B/W duplex , Copying: up to 53 ppm (A4) - B/W
1 x USB 2.0 , 1 x USB host , 1 x LAN
Network Protocols
TCP/IP, IPX/SPX, AppleTalk, DLC/LLC
Operating System Support
MS Windows XP, MS Windows 2000, Apple Mac OS X, HP-UX 11.x, MS Windows Server 2003, Apple Mac OS 9.x, IBM AIX 5.2, Sun Solaris 8, Sun Solaris 9, MS Windows XP Professional x64 Edition, SuSe Linux 8.0, Red Hat Enterprise Linux WS 3.0, Red Hat Enterprise Linux WS 4.0, SuSE Linux 9.0, MS Windows Vista, MS Windows 2000 Server, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), IBM AIX 5L 5.3, Sun Solaris 10, SuSe Linux 10.x, Debian Linux, Ubuntu Linux, MS Windows Server 2008
First Copy Out Time B/W
7.5 sec
Consumables Included
1 x toner cartridge (black) - up to 18000 pages
FCC Class A certified, BSMI CNS 13438 Class A, NOM, VCCI Class A ITE, IEC 60320-1, JATE, ICES-003 Class A, CS-03, UL 60950-1, CSA C22.2 No. 60950-1-03, FDA
ENERGY STAR Certified
Limited warranty - 1 year - on-site - response time: next business day
54.8 cm
61.1 cm
88.5 cm
45.4 kg
Sound Emission
29 dBA (idle) / 56 dBA (operating)
16 °C
32 °C
8 - 80%
