Lexmark X544N MFP
Lexmark X544N MFP
Quicklinx: 68GJWS00 Mfr#: 26D0014
Great value for small and midsize workgroups, the network-ready Lexmark X544n offers quality printing, copying, faxing, and duplex scanning, plus output speeds up to 25 ppm in black and color. Lower your costs with extra-high-yield cartridges, and maximize business performance with a wide range of advanced scanning features. Built for serious office work, X544n equips you with all the productivity functions you need to maximize your business performance. Move easily between hardcopy and digital documents with advanced scanning, such as scan to desktop, scan to e-mail or scan to shared server.
  • Compelling Colour Value
    A great value for small or midsize workgroups, with high-quality printing, copying, faxing and duplex scanning, plus output speeds up to 23 ppm in black and colour. Lower your running costs with Lexmark Extra High Yield Toner Cartridges and the money-saving Lexmark Rewards program.
  • Great Colour, No Sacrifice
    PANTONE calibrated colour adds impact to every impression you make and Lexmark High Yield Toner Cartridges keep printing costs low-a smart combination for hardworking offices.
  • Eco-Responsible
    Saving resources means everyone wins-your business, your budget and the environment! Eco-features include energy-saving Eco-Mode and an instant warm-up fuser to help you print greener at every level. And toner cartridges for the Lexmark X540 Series never require shaking to deliver their full declared yield.
  • Save Money and the Planet
    Lexmark supplies help protect the environment, too. Using Lexmark High Yield Toner Cartridges conserves resources by reducing the number of cartridges you use over the life of your printer.
Lexmark X544n - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
55000 impressions
Max Copying Speed
Up to 23 ppm (mono) / up to 23 ppm (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Original Size
216 x 355 mm (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
216 x 356 mm (max)
Media Type
Transparencies, plain paper, cards, labels
Standard Media Capacity
250 sheets
Max Media Capacity
900 sheets
Output Trays Capacity
150 sheets
Connection Availability
USB 2.0, LAN, USB host
AC 120 V
44 cm x 53.7 cm x 46.3 cm
27.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
55000 impressions
Display
2 lines x 16 characters
Standard Memory
128 MB 128 MB
Max Supported Memory
640 MB 640 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Printing
Max Printing Speed
Image Enhancement Technology
4800CQ
First Print Out Time B/W
13 sec
First Print Out Time Colour
13 sec
Scanning
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
PC Faxing
Document & Media Handling
Max Original Size
216 x 355 mm
Original Type
Sheets
50 sheets
Max Media Size
Other
Supported Media Type
250 sheets
Max Media Capacity
900 sheets
150 sheets
ADF - 50 sheets - Legal (216 x 356 mm) weight: 75 g/m² , Input tray - 250 sheets - 216 x 432 mm weight: 75 g/m²
Speed Details
Copying: up to 25 ppm (Letter A) - colour , Copying: up to 25 ppm (Letter A) - B/W , Copying: up to 23 ppm (A4) - colour , Copying: up to 23 ppm (A4) - B/W , Printing: up to 25 ppm (Letter A) - colour , Printing: up to 25 ppm (Letter A) - B/W , Printing: up to 23 ppm (A4) - colour , Printing: up to 23 ppm (A4) - B/W
1 x USB 2.0 , 1 x USB host , 1 x LAN
Network Protocols
TCP/IP, AppleTalk
Operating System Support
MS Windows XP, MS Windows 2000, Apple Mac OS X, HP-UX 11.x, MS Windows Server 2003, Apple Mac OS 9.x, IBM AIX 5.2, Sun Solaris 8, Sun Solaris 9, MS Windows XP Professional x64 Edition, SuSe Linux 8.0, Red Hat Enterprise Linux WS 3.0, Red Hat Enterprise Linux WS 4.0, SuSE Linux 9.0, MS Windows Vista, MS Windows 2000 Server, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), IBM AIX 5L 5.3, Sun Solaris 10, SuSe Linux 10.x, Debian Linux, Ubuntu Linux, MS Windows Server 2008
AC 120 V
First Copy Out Time B/W
16.5 sec
Consumables Included
1 x toner cartridge (yellow) - up to 2000 pages , 1 x toner cartridge (magenta) - up to 2000 pages , 1 x toner cartridge (cyan) - up to 2000 pages , 1 x toner cartridge (black) - up to 2500 pages
FCC Class B certified, CSA, TUV GS, SEMKO, IEC 60950, UL 60950 Third Edition, CB, C-Tick Class B, CCC
ENERGY STAR Certified
Limited warranty - 1 year - on-site - response time: next business day
44 cm
53.7 cm
46.3 cm
27.2 kg
Sound Emission
51 dBA (operating)
16 °C
32 °C
8 - 80%
