Wi-Fi N for Intense Productivity
Wi-Fi N gives you the freedom of wireless with 3x the coverage and faster transfer speeds than the previous wireless technology(1). Take advantage of Wi-Fi Protected Set-up to simplify the wireless set-up process. An Ethernet port gives you even more options. -
The Industry's Best Guarantee
Focus on work and leave the worry to us, thanks to a 5-year guarantee plus lifetime priority phone support (2). When we say reliable, we mean business. -
Increase Your Efficiency
An included XL black cartridge and 3 individual colour cartridges helps save resources and lowers printing costs. -
Efficiency Built In
Spend more time managing success, and less time managing paper supply with 150-page input capacity and 50 page automatic document feeder. Save money and resources with automatic two-sided printing. -
Scan and Import Business Cards
This advanced technology allows you to easily scan and save information from business cards, such as name, address and phone number. Rather than entering the information manually, you can scan up to 8 cards at a time and synch it with your address book software(3). That's real time saved.
- Lexmark Prevail Pro705 - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Lexmark Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 10000 impressions
- Max Copying Speed
- Up to 25 ppm (mono) / up to 21 ppm (colour)
- Max Printing Speed
- Up to 33 ppm (mono) / up to 30 ppm (colour)
- Max Printing Resolution
- Up to 2400 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 4800 dpi
- Display
- 2.4"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 216 x 432 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, iron-on transfers, photo paper, banner
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 50 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- 46.5 cm x 39.2 cm x 25 cm
- 9.3 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 5-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Ink-jet - colour
- 10000 impressions
- Display Diagonal Size
- 2.4"
- Interface
- Standard Memory
- 64 MB 64 MB
- Supported Flash Memory
- Memory Stick, SD Memory Card, MultiMediaCard, xD-Picture Card, Memory Stick PRO
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
Printing
- Inkjet Technology
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 4800 dpi
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Borderless Photo Sizes
- 100 x 150 mm
- 150 sheets
- 50 sheets
- Input tray - 150 sheets , Output tray - 50 sheets , ADF - 50 sheets
- Speed Details
- Printing: up to 33 ppm - B/W draft , Printing: up to 30 ppm - colour draft , Printing: up to 16 ppm - B/W normal , Printing: up to 10 ppm - colour normal , Copying: up to 25 ppm - B/W draft , Copying: up to 21 ppm - colour draft , Copying: up to 15 ppm - B/W normal , Copying: up to 8 ppm - colour normal
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- Operating System Support
- MS Windows XP, MS Windows 2000 SP4 or later, MS Windows XP Professional x64 Edition, MS Windows 7, Apple Mac OS X 10.3.9, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.4.4 - 10.5.x
- Direct Printing Specifications
- PictBridge
- FCC Class B certified, CSA, TUV GS, VCCI Class B ITE, CCIB, SEMKO, IEC 60950, UL 60950 Third Edition, CB, C-Tick Class B, ICES Class B, CCC Class B, BSMI Class B, PSE Mark, IEC 60825-1, cULus
- ENERGY STAR Certified
- Limited warranty - 5 years , Limited warranty - replacement - 1 year
- 46.5 cm
- 39.2 cm
- 25 cm
- 9.3 kg
- Shipping Width
- 54.2 cm
- Shipping Depth
- 33 cm
- Shipping Height
- 48.6 cm
- Shipping Weight
- 12.1 kg
- Sound Emission
- 52 dBA (operating)
