The Lexmark MX611dhe with fax helps propel your business forward with productivity solutions, 2-sided printing and more data capacity - plus fast processor, print, copy and scan speeds. The Lexmark MX611dhe MFP with print, copy, fax, email and scan functions prints up to 50 ppm. Included are 2-sided printing and 650 sheets of input.
Faster Processing
Improve your print, scan and copy speeds by taking advantage of up to 3 GB of upgradeable memory, an 800 MHz dual-core processor and Gigabit Ethernet. -
Keep Jobs Moving
With a maximum input capacity of up to 2,300 sheets and an ultra high yield toner cartridge, you'll rarely have to add paper or change cartridges. -
Get Work Done Quickly
Enjoy print speeds up to 47 pages per minute, plus print or copy your first page in as little as 6.5 seconds. -
Smart and Easy to Use
A vibrant 17.8 cm (7 inch) colour touch screen provides access to pre-installed productivity solutions and lets you operate the system via smart and intuitive navigation. -
Work Smarter Not Harder
If you can use a mobile phone application, you can use our pre-loaded solutions. Touch the screen and access shortcuts that let you scan, print or send faxes, emails and other business-critical documents fast.
- Lexmark MX611dhe - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 150000 impressions
- Recommended Monthly Volume
- 2000 - 15000 pages
- Max Copying Speed
- Up to 47 ppm
- Max Printing Speed
- Up to 47 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 600 dpi (600 x 600 dpi color)
- Display
- 7"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 2300 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, 2 x USB host
- Office Machine Features
- Scan to network, hard disk included
- 48.9 cm x 47.9 cm x 56.1 cm
- 23.6 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - monochrome
- Display Diagonal Size
- 7"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 1024 MB 1 GB
- Max Supported Memory
- 3072 MB 3 GB
Copying
- Max Copying Speed
- Up to 47 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
Printing
- Up to 47 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PPDS, PDF 1.7, XPS
- Image Enhancement Technology
- 1200 IQ, 2400 IQ
- First Print Out Time B/W
- 6.5 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- PC Faxing
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 120 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- 650 sheets
- 2300 sheets
- 100 sheets
- 250 sheets
- ADF - 50 sheets - Legal (216 x 356 mm) , Bypass tray - 100 sheets , Input tray - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Output tray - 250 sheets
- Speed Details
- Printing: up to 47 ppm (A4) - B/W , Printing: up to 20 spm (A4) - B/W duplex , Copying: up to 47 ppm (A4) - B/W , Copying: up to 23 spm (A4) - B/W duplex , Scanning: up to 45 ppm (A4) - B/W , Scanning: up to 48 ppm (Letter A) - B/W , Scanning: up to 30 ppm (A4) - colour , Scanning: up to 32 ppm (Letter A) - colour , Scanning: up to 20 ppm (A4) - B/W duplex , Scanning: up to 21 ppm (Letter A) - B/W duplex , Scanning: up to 13 ppm (A4) - colour duplex , Scanning: up to 14 ppm (Letter A) - colour duplex
- 1 x USB 2.0 , 2 x USB host , 1 x Gigabit LAN
- SSL, Apple Bonjour, LEAP, TLS, IPsec, 802.1x, ARP
- Operating System Support
- MS Windows XP, MS Windows 98, Novell NetWare 6, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, Apple Mac OS X 10.5, Red Hat Enterprise Linux WS 4.0, MS Windows 7, Red Hat Enterprise Linux WS 5.0, SuSE Linux Enterprise Server 10, SuSE Linux Enterprise Server 11, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, Debian GNU/Linux 5.0, Red Flag Linux Desktop 6.0, HP-UX 11.11, HP-UX 11.23, HP-UX 11.31, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, IBM AIX 5.3, Novell NetWare 5.1, Novell NetWare 6.5, SunSoft Solaris x86 10, IBM AIX 6.1, Apple Mac OS X 10.6, openSUSE 11.3, Linux Linpus Desktop 9.6, MS Windows Server 2008 R2, Fedora 14, openSUSE 11.4, Apple Mac OS X 10.7, Red Hat Enterprise Linux WS 6.0, Debian GNU/Linux 6.0, IBM AIX 7.1, Ubuntu Linux 11.04, Fedora 15, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8
- Software Included
- Drivers & Utilities
- 660 Watt
- Power Consumption Standby
- 20 Watt
- Power Consumption Sleep
- 7.5 Watt
- First Copy Out Time B/W
- 6.5 sec
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge - up to 7500 pages
- FCC Class B certified, TUV GS, VCCI Class B ITE, CISPR 22 Class B, SEMKO, EN55024, EN55022 Class B, ICES-003 Class B, C-Tick Class B, EK, UL 60950-1, TUV Rh, CCC Class B, BSMI CNS 13438, IEC 60825-1, FDA, Nemko N-mark, UL-AR, EN 60825-1, CAN/CSA-C22.2 No. 60950-1
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year - on-site - response time: next business day
- 48.9 cm
- 47.9 cm
- 56.1 cm
- 23.6 kg
- Shipping Width
- 57.2 cm
- Shipping Depth
- 59.9 cm
- Shipping Height
- 67.3 cm
- Shipping Weight
- 28 kg
- Sound Emission
- 56 dBA (operating)
- 16 °C
- 32 °C
- 8 - 80%
Lexmark 502X Extra High Yield Return Program Toner 10K | In Stock | £224.79 |
Lexmark 602 High Return Toner Cartridge | In Stock | £224.79 |
Lexmark 500Z Black Return Program Imagining Unit | In Stock | £39.87 |
Lexmark 502U Ultra High Yield Return Program Toner | In Stock | £338.68 |
Lexmark 602 Return Program Cartridge 2.5K | In Stock | £90.13 |
Lexmark 502UE Ultra High Yield Corporate Cartridge | In Stock | £338.68 |
Lexmark 502XE Black Extra High Yield Toner Cartridge | In Stock | £224.79 |
Lexmark 602XE Black High Yield Return Program Toner Cartridge | In Stock | £338.68 |
Lexmark 500ZA Black Imaging Unit | In Stock | £72.08 |
