The Lexmark MS823n features a first page as fast as 4.2 seconds and output up to 65 pages per minute.
Engineered to last
Steel frames and a robust paper feeding system that reliably handles diverse media types and sizes support heavy-duty use and a long life in even the harshest environments. -
Ready to work
With access to input capacity of up to 4400 sheets, replacement toner cartridges that go as high as 55,000 pages, long-life imaging unit and a fuser that may never need replacement, you'll spend more time printing. Plus, innovations in part replacement and accessibility help you resolve problems quickly. -
Fast start + enduring performance
A first page as fast as 4.2 seconds sets the stage for printing and copying up to 65 [61] ppm. And support for large workloads is built in, with recommended monthly page volume as high as 350,000 pages.
- Lexmark MS823n - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 25.4 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 61 ppm - B/W (ISO/IEC 24734) , Up to 37 spm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution Class (B&W)
- 1200 x 1200 dpi
- Image Enhancement Technology
- 2400 IQ
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Preview Screen Size
- 2.4"
- Processor
- 1000 MHz
- RAM Installed (Max)
- 512 MB (4.5 GB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, XPS, PDF 1.7
- Barcodes
- OCR-A, OCR-B
- Media Type
- Envelopes, transparencies, labels, plain paper, card stock
- Total Media Capacity
- 650 sheets
- Media Handling
- 100-sheet multipurpose tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 300000 pages
- Recommended Monthly Volume
- 5000 - 75000 pages
- Networking
- Print server
- Printer Features
- Internal card slot
- System Requirements
- SunSoft Solaris x86 10, SuSE Linux Enterprise Server 11, Apple MacOS X 10.6, SuSE Linux Enterprise Server 10, IBM AIX 6.1, Microsoft Windows 7 (32/64 bits), SunSoft Solaris SPARC Platform Edition 10, Apple MacOS X Lion 10.7, IBM AIX 7.1, SunSoft Solaris x86 11, Red Hat Enterprise Linux WS 6, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), SunSoft Solaris SPARC Platform Edition 11, Debian GNU/Linux 7.0, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10, SuSE Linux Enterprise Server 12, Apple MacOS X 10.11, Debian GNU/Linux 8.0, Red Hat Enterprise Linux WS 7, Ubuntu 16.04 LTS, SUSE Linux 13.2, Apple macOS 10.12, Linux Fedora 23, Linux Fedora 24, openSUSE 42.3
- 1-year warranty
- 42.8 cm x 51 cm x 44.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- 2.4"
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- 2400 IQ
- PostScript Support
- Standard
- First Print Out Time B/W
- 4.2 sec
- Fonts Included
- 158 x scalable PostScript , 2 x bitmapped PCL , 84 x scalable PCL , 39 x scalable PPDS , 5 x bitmapped PPDS
- Barcodes
- OCR-A, OCR-B
- Printer Features
- Media Handling
- Processor
- 1000 MHz
RAM
- 512 MB / 4.5 GB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- 650 sheets
- Media Feeders
- Bypass tray: 1 - 100 sheets , Input tray: 1 - 550 sheets weight: 60 g/m² - 176 g/m² - (16 lbs (min) - 47 lbs (max)) , Output tray: 1 - 550 sheets
- Max Media Capacity
- 4400 sheets
- Output Trays Capacity
- 550 sheets
Duty Cycle
- 300000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, IPP 1.0, IPP 1.1, IPP 2.0
- SSL, LEAP, TLS, 802.1x, TTLS, PEAP, MD5, EAP-MSCHAPv2
- Connections
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x Gigabit LAN - RJ-45 ¦ 1 x USB 2.0 host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 11000 pages ISO/IEC 19752 , 1 x imaging unit - up to 150000 pages at 5% coverage
- FCC Class B certified, C-Tick, GS, NOM, ICES-003 Class B, CCC, DOC, SII, UL 60950-1, BSMI Class B, KCC, IEC 60825-1, FDA, UL-AR, GOST-R, EN 60825-1, KC, CECP, CEL, VCCI Class B, Directive 1275/2008/EC, ECMA-370, EFTA, TER, ISO 532B, TED, IEC/EN 60950-1, CAN/CSA-C22.2 No. 60950-1
- Power Device
- Power supply - internal
- 800 Watt
- Power Consumption Stand by
- 34 Watt
- Power Consumption Sleep
- 1.6 Watt
- OS Required
- Limited warranty - 1 year - on-site - response time: next business day
- 10 °C
- 32 °C
- 8 - 80%
- Sound Emission (Idle)
- 14 dBA
- Sound Emission (Operating)
- 58 dBA
- 42.8 cm
- 51 cm
- 44.5 cm
- 25.4 kg
- Width (Shipping)
- 55 cm
- Depth (Shipping)
- 65 cm
- Height (Shipping)
- 56.5 cm
- Weight (Shipping)
- 29.9 kg
