Handle complex specialty media effortlessly. The Lexmark MS725dvn reliably prints in a wide range of sizes on diverse materials - from small, narrow-format papers to vinyl outdoor media.
Versatile media support
Take advantage of a wide range of sizes and diverse materials-from small, narrow-format papers to vinyl outdoor media. With its excellent feed reliability, the MS725dvn is superior at printing media as narrow as 3 inches (76 mm) wide. -
Built for heavy workloads
A powerful combination of 1-GHz dual-core processor and 512 MB memory supports printing at up to 55 [52] ppm. With access to input capacity of up to 4400 sheets, replacement toner cartridges that go as high as 55,000 pages, long-life imaging unit and a fuser that may never need replacement, you'll spend more time printing and less time doing maintenance. -
Engineered to last
A steel frame and a robust paper feeding system that reliably handles diverse media types and sizes support heavy-duty use and a long life in even the harshest environments. -
Interact with ease
With new front power button and USB port, 2.4-inch colour LCD/keypad to monitor and configure system settings and single-door access to parts and supplies, it's easier than ever to get things done. Convenient front access to the paper path means you'll virtually never have to access the back of the device, allowing placement in or on cabinets. And ADA-compliant trays have push-button sliders and open with one hand, requiring low force and no twisting. -
Innovation that saves
In addition to inactivity-based sleep mode, you can invoke sleep by simply pressing the new front power button. Lexmark-exclusive Quiet Mode reduces noise pollution by reducing sound by up to 5dBA, while Eco Mode lets you reduce energy consumption and enforce two-sided printing to save paper. -
Full-spectrum security
Lexmark's comprehensive approach to product security is a design and engineering mandate across our entire product portfolio. Our security features help keep your information safe-in the document, on the device, over the network and at all points in between. That's why Keypoint Intelligence - Buyers Lab honored Lexmark with a prestigious BLI PaceSetter award for Document Imaging Security. And this Lexmark product enables you to be GDPR ready.
- Lexmark MS725dvn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 25.4 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 52 ppm - B/W (ISO/IEC 24734) , Up to 32 spm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 600 x 600 dpi
- Max Resolution Class (B&W)
- 600 x 600 dpi
- Image Enhancement Technology
- 2400 IQ
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Preview Screen Size
- 2.4"
- Processor
- 1000 MHz
- RAM Installed (Max)
- 512 MB (4.5 GB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, XPS, PDF 1.7
- Barcodes
- OCR-A, OCR-B
- Media Type
- Transparencies, labels, plain paper, vinyl, card stock
- Total Media Capacity
- 650 sheets
- Media Handling
- 100-sheet multipurpose tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 300000 pages
- Recommended Monthly Volume
- 5000 - 75000 pages
- Networking
- Print server
- Printer Features
- Internal card slot
- System Requirements
- Novell NetWare 6.5, Novell NetWare 5.1 SP6 or later, Novell NetWare 6.0 SP3 or later, SunSoft Solaris x86 10, SuSE Linux Enterprise Server 11, Apple MacOS X 10.6, SuSE Linux Enterprise Server 10, IBM AIX 6.1, Microsoft Windows 7 (32/64 bits), SunSoft Solaris SPARC Platform Edition 10, Apple MacOS X Lion 10.7, IBM AIX 7.1, SunSoft Solaris x86 11, Red Hat Enterprise Linux WS 6, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), SunSoft Solaris SPARC Platform Edition 11, Debian GNU/Linux 7.0, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10, SuSE Linux Enterprise Server 12, Apple MacOS X 10.11, Debian GNU/Linux 8.0, Red Hat Enterprise Linux WS 7, Ubuntu 16.04 LTS, SUSE Linux 13.2, Apple macOS 10.12, Linux Fedora 23, Linux Fedora 24, openSUSE 42.3
- 1-year warranty
- 42.8 cm x 51 cm x 44.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- 2.4"
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 600 x 600 dpi
- 600 x 600 dpi
- 2400 IQ
- PostScript Support
- Standard
- First Print Out Time B/W
- 8 sec
- Fonts Included
- 158 x scalable PostScript , 2 x bitmapped PCL , 84 x scalable PCL , 39 x scalable PPDS , 5 x bitmapped PPDS
- Barcodes
- OCR-A, OCR-B
- Printer Features
- Media Handling
- Processor
- 1000 MHz
RAM
- 512 MB / 4.5 GB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- 650 sheets
- Media Feeders
- Bypass tray: 1 - 100 sheets , Input tray: 1 - 550 sheets weight: 60 g/m² - 176 g/m² , Output tray: 1 - 550 sheets
- Max Media Capacity
- 4400 sheets
- Output Trays Capacity
- 550 sheets
Duty Cycle
- 300000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, IPP 1.0, IPP 1.1, IPP 2.0
- SSL, LEAP, TLS, 802.1x, TTLS, PEAP, MD5, EAP-MSCHAPv2
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) , 1 x imaging unit - up to 150000 pages at 5% coverage
- FCC Class B certified, C-Tick, GS, NOM, ICES-003 Class B, CCC, DOC, SII, UL 60950-1, BSMI Class B, KCC, IEC 60825-1, FDA, UL-AR, GOST-R, EN 60825-1, KC, CECP, CEL, VCCI Class B, Directive 1275/2008/EC, ECMA-370, EFTA, TER, MET, ISO 532B, TED, IEC/EN 60950-1, CAN/CSA-C22.2 No. 60950-1
- Power Device
- Power supply - internal
- 690 Watt
- Power Consumption Stand by
- 95 Watt
- Power Consumption Sleep
- 1.3 Watt
- OS Required
- Limited warranty - 1 year - on-site - response time: next business day
- 10 °C
- 32 °C
- 8 - 80%
- Sound Emission (Idle)
- 28 dBA
- Sound Emission (Operating)
- 56 dBA
- 42.8 cm
- 51 cm
- 44.5 cm
- 25.4 kg
- Width (Shipping)
- 55 cm
- Depth (Shipping)
- 65 cm
- Height (Shipping)
- 56.5 cm
- Weight (Shipping)
- 31 kg
Lexmark Staples | In Stock | £117.46 |
