Lexmark MS725dvn Mono Laser A4 52 ppm Special Media Printer
Quicklinx: F3CHWS00 Mfr#: 50G0635
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£787.14 ex VAT
£944.56 inc VAT
Handle complex specialty media effortlessly. The Lexmark MS725dvn reliably prints in a wide range of sizes on diverse materials - from small, narrow-format papers to vinyl outdoor media.
  • Versatile media support
    Take advantage of a wide range of sizes and diverse materials-from small, narrow-format papers to vinyl outdoor media. With its excellent feed reliability, the MS725dvn is superior at printing media as narrow as 3 inches (76 mm) wide.
  • Built for heavy workloads
    A powerful combination of 1-GHz dual-core processor and 512 MB memory supports printing at up to 55 [52] ppm. With access to input capacity of up to 4400 sheets, replacement toner cartridges that go as high as 55,000 pages, long-life imaging unit and a fuser that may never need replacement, you'll spend more time printing and less time doing maintenance.
  • Engineered to last
    A steel frame and a robust paper feeding system that reliably handles diverse media types and sizes support heavy-duty use and a long life in even the harshest environments.
  • Interact with ease
    With new front power button and USB port, 2.4-inch colour LCD/keypad to monitor and configure system settings and single-door access to parts and supplies, it's easier than ever to get things done. Convenient front access to the paper path means you'll virtually never have to access the back of the device, allowing placement in or on cabinets. And ADA-compliant trays have push-button sliders and open with one hand, requiring low force and no twisting.
  • Innovation that saves
    In addition to inactivity-based sleep mode, you can invoke sleep by simply pressing the new front power button. Lexmark-exclusive Quiet Mode reduces noise pollution by reducing sound by up to 5dBA, while Eco Mode lets you reduce energy consumption and enforce two-sided printing to save paper.
  • Full-spectrum security
    Lexmark's comprehensive approach to product security is a design and engineering mandate across our entire product portfolio. Our security features help keep your information safe-in the document, on the device, over the network and at all points in between. That's why Keypoint Intelligence - Buyers Lab honored Lexmark with a prestigious BLI PaceSetter award for Document Imaging Security. And this Lexmark product enables you to be GDPR ready.
Lexmark MS725dvn - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
25.4 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 52 ppm - B/W (ISO/IEC 24734) , Up to 32 spm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
600 x 600 dpi
Max Resolution Class (B&W)
600 x 600 dpi
Image Enhancement Technology
2400 IQ
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Preview Screen Size
2.4"
1000 MHz
RAM Installed (Max)
512 MB (4.5 GB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, XPS, PDF 1.7
Barcodes
OCR-A, OCR-B
Media Type
Transparencies, labels, plain paper, vinyl, card stock
Total Media Capacity
650 sheets
Media Handling
100-sheet multipurpose tray, 550-sheet input tray
Monthly Duty Cycle (max)
300000 pages
Recommended Monthly Volume
5000 - 75000 pages
Print server
Printer Features
Internal card slot
Novell NetWare 6.5, Novell NetWare 5.1 SP6 or later, Novell NetWare 6.0 SP3 or later, SunSoft Solaris x86 10, SuSE Linux Enterprise Server 11, Apple MacOS X 10.6, SuSE Linux Enterprise Server 10, IBM AIX 6.1, Microsoft Windows 7 (32/64 bits), SunSoft Solaris SPARC Platform Edition 10, Apple MacOS X Lion 10.7, IBM AIX 7.1, SunSoft Solaris x86 11, Red Hat Enterprise Linux WS 6, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), SunSoft Solaris SPARC Platform Edition 11, Debian GNU/Linux 7.0, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10, SuSE Linux Enterprise Server 12, Apple MacOS X 10.11, Debian GNU/Linux 8.0, Red Hat Enterprise Linux WS 7, Ubuntu 16.04 LTS, SUSE Linux 13.2, Apple macOS 10.12, Linux Fedora 23, Linux Fedora 24, openSUSE 42.3
1-year warranty
42.8 cm x 51 cm x 44.5 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Preview Screen Size
2.4"
Wired
AirPrint Enabled
600 x 600 dpi
600 x 600 dpi
2400 IQ
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
8 sec
Language Simulation
Fonts Included
158 x scalable PostScript , 2 x bitmapped PCL , 84 x scalable PCL , 39 x scalable PPDS , 5 x bitmapped PPDS
Barcodes
OCR-A, OCR-B
Printer Features
Internal card slot
Media Handling
1000 MHz
RAM
RAM Installed (Max)
512 MB / 4.5 GB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
650 sheets
Media Feeders
Bypass tray: 1 - 100 sheets , Input tray: 1 - 550 sheets weight: 60 g/m² - 176 g/m² , Output tray: 1 - 550 sheets
Max Media Capacity
4400 sheets
Output Trays Capacity
550 sheets
Duty Cycle
300000 pages
5000 - 75000 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, IPP 1.0, IPP 1.1, IPP 2.0
Security Protocols & Features
SSL, LEAP, TLS, 802.1x, TTLS, PEAP, MD5, EAP-MSCHAPv2
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) , 1 x imaging unit - up to 150000 pages at 5% coverage
FCC Class B certified, C-Tick, GS, NOM, ICES-003 Class B, CCC, DOC, SII, UL 60950-1, BSMI Class B, KCC, IEC 60825-1, FDA, UL-AR, GOST-R, EN 60825-1, KC, CECP, CEL, VCCI Class B, Directive 1275/2008/EC, ECMA-370, EFTA, TER, MET, ISO 532B, TED, IEC/EN 60950-1, CAN/CSA-C22.2 No. 60950-1
Power supply - internal
690 Watt
Power Consumption Stand by
95 Watt
Power Consumption Sleep
1.3 Watt
Limited warranty - 1 year - on-site - response time: next business day
10 °C
32 °C
8 - 80%
Sound Emission (Idle)
28 dBA
Sound Emission (Operating)
56 dBA
42.8 cm
51 cm
44.5 cm
25.4 kg
Width (Shipping)
55 cm
Depth (Shipping)
65 cm
Height (Shipping)
56.5 cm
Weight (Shipping)
31 kg
Brand: Lexmark
Price Range Ex VAT: £750 - £1000
