Lexmark MB2770adwhe Mono Laser Multifunction Printer
Quicklinx: F8GXWS00 Mfr#: 25B0227
A hard disk helps the flexibly configurable, Wi-Fi- and OCR-equipped Lexmark MB2770adwhe monochrome multifunction product to meet large-workgroup needs.
  • 4-year guarantee upon registration
    For an added level of peace of mind, you can benefit from 4-year guarantee coverage upon registration.
  • The wireless difference
    In addition to standard Ethernet and USB connectivity, on-board 802.1x-standard Wi-Fi makes it easy for authorised users to directly and securely connect for access to device services such as scanning and printing.
  • Don't interrupt
    With access to input capacity of up to 3,300 sheets, replacement toner cartridges that go as high as 30,000 pages, 200-sheet automatic document feeder, long-life imaging unit and fuser that may never need replacement, you'll spend more time printing and less time doing maintenance.
  • Blazing output, amazing input
    A first page as fast as four seconds sets the stage for printing and copying at up to 66 ppm, backed by the powerful combination of 1.2-GHz quad-core processor, standard hard disk and up to 6 GB of memory. Single-pass two-sided scanning at up to 144 spm completes the speed equation, bolstered by bigger-than-ever 200-page document feeder capacity.
  • Interact with ease
    With new front-side power button and USB port, 17.8 cm class [7-inch] colour e-Task touch screen to monitor and configure system settings and single-door access to parts and supplies, it's easier than ever to get things done. Convenient front access to the paper path means you'll virtually never have to access the back of the device. And ADA-compliant trays have push-button sliders and open with one hand, requiring low force and no twisting.
  • Innovation that saves
    Lexmark's most energy-efficient large-workgroup monochrome products ever are rated EPEAT Gold and ENERGY STAR (2.0) certified. In addition to inactivity-based sleep mode, you can invoke sleep by simply pressing the new front-side power button. Lexmark-exclusive Quiet Mode reduces noise pollution by reducing sound by up to 5dBA, while Eco Mode lets you reduce energy consumption and enforce two-sided printing to save paper.
  • Full-spectrum security
    Lexmark's comprehensive approach to product security is a design and engineering mandate across our entire product portfolio. Our security features help keep your information safe - in the document, on the device, over the network and at all points in between. That's why Keypoint Intelligence - Buyers Lab honoured Lexmark with a prestigious BLI PaceSetter award for Document Imaging Security. And this Lexmark product enables you to be GDPR ready.
Lexmark MB2770adhwe - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
350000 pages
Recommended Monthly Volume
5000 - 100000 pages
Max Copying Speed
Up to 66 ppm
Max Printing Speed
Up to 66 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Printing Resolution Class
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Display
7"
Original Size
215.9 x 355.6 mm (max)
Original Type
Sheets
Document Feeder Capacity
200 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, card stock
Standard Media Capacity
650 sheets
Max Media Capacity
3300 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
550 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB 2.0 host
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to network, hard disk included, scan to FTP, scan to USB host, internal card slot
55.88 cm x 57.84 cm x 73.91 cm
44.1 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
4-year warranty with product registration
Printer Fonts
Bitmapped PCL x 2 , Scalable PCL x 84 , Scalable PostScript x 158 , Bitmapped PPDS x 5 , Scalable PPDS x 39
Fax Type
Plain paper
Printing Technology
Laser - monochrome
350000 pages
5000 - 100000 pages
Display Diagonal Size
7"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
2 GB
Max Supported Memory
6 GB
Hard Disk Drive
160 GB
Copying
Max Copying Speed
Up to 66 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Automatic Duplexing
Printing
Max Printing Speed
Up to 66 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PPDS, PDF 1.7, XPS
Image Enhancement Technology
1200 IQ, 2400 IQ
Automatic Duplexing
First Print Out Time B/W
4.5 sec
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Document & Media Handling
Max Original Size
215.9 x 355.6 mm
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 215.9 x 355.6 mm
Original Type
Sheets
200 sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
650 sheets
Max Media Capacity
3300 sheets
100 sheets
550 sheets
Multi-purpose tray - 100 sheets , Input tray - 550 sheets weight: 60 g/m² - 176 g/m² , RADF - 200 sheets , Output tray - 550 sheets
Speed Details
Printing: up to 66 ppm - B/W , Printing: up to 40 ppm (A4) - B/W duplex , Copying: up to 66 ppm (A4) - B/W , Copying: up to 42 ppm (A4) - B/W duplex , Scanning: up to 72 spm (A4) - B/W , Scanning: up to 75 spm (Letter A) - B/W , Scanning: up to 72 spm (A4) - colour , Scanning: up to 75 spm (Letter A) - colour , Scanning: up to 144 spm (A4) - B/W duplex , Scanning: up to 150 spm (Letter A) - B/W duplex , Scanning: up to 144 spm (A4) - colour duplex , Scanning: up to 150 spm (Letter A) - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 3 x USB 2.0 host - 4 pin USB Type A
Security Protocols & Features
SSL, LEAP, TLS, IPsec, 802.1x, ARP, TTLS, PEAP, MD5, MS-CHAPv2, SNMP 3
Operating System Support
Novell NetWare 6, SuSE Linux Enterprise Server 10, SuSE Linux Enterprise Server 11, Novell NetWare 5.1, Novell NetWare 6.5, SunSoft Solaris x86 10, IBM AIX 6.1, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Red Hat Enterprise Linux WS 6.0, IBM AIX 7.1, Apple Mac OS X 10.8, SunSoft Solaris x86 11, SunSoft Solaris SPARC Platform Edition 10, SunSoft Solaris SPARC Platform Edition 11, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Debian Linux 7.0, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10, Apple Mac OS X 10.11, openSUSE 13.2, Novell Open Enterprise Server 2, Debian Linux 8.0, SuSE Linux Enterprise Server 12, Novell Open Enterprise Server 11, Red Hat Enterprise Linux WS 7.0, macOS 10.12, Fedora Linux 23, Fedora Linux 24, openSUSE 42.3, Ubuntu Linux 16.04 LTS
Software Included
Drivers & Utilities
890 Watt
Power Consumption Standby
42 Watt
Power Consumption Sleep
2 Watt
First Copy Out Time B/W
4 sec
Consumables Included
1 x toner cartridge (black) - up to 25000 pages ISO/IEC 19752 , 1 x imaging unit - up to 150000 pages at 5% coverage
FCC Class A certified, C-Tick, CISPR 22 Class A, cUL, GS, NOM, CB, CCC, DOC, ICES-003 Class A, SII, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, A-Tick, IEC 60825-1, FDA, UL-AR, GOST-R, EN 60825-1, BSMI Class A, CDRH, KC, CECP, CEL, VCCI Class A, Bel GISS, ECMA-370, EFTA, TER, MET, ISO 532B, TED, CCD 035 EcoLogo, CAN/CSA-C22.2 No. 60950-1
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 4 Years
55.88 cm
57.84 cm
73.91 cm
44.1 kg
Sound Emission
14 dBA (idle) / 60 dBA (operating)
10 °C
32 °C
8 - 80%
