Place assets where they are needed - printer location is functionally and economically driven, not constrained by existing LAN connections. SNMPv3 supports encrypted and authenticated management traffic protecting remote configuration and device status messages. IPSec can be used with both TCP/IP IPv4 and IPv6 networks and provides encryption and authentication of communications at the network layer.
A print server to connect to most major wireless networks via the 2.4 GHz band using one RP-SMA connector with antenna.
Freedom
Place assets where they are needed - printer location is functionally and economically driven, not constrained by existing LAN connections. -
Easy setup
Wired and wireless configuration - configure using a USB cable or without any cables. -
Embedded web page
The embedded web page allows administrators to flash update printer firmware or access printer settings using a web browser to easily monitor printer status and change default settings. -
Network communications security
- Lexmark MarkNet N8350 - print server
- Print server
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 72 Mbps
- TCP/IP, AppleTalk, UDP/IP, NTP, ICMP/IP, IPSec, LPR/LPD, ARP, FTP, BOOTP, DHCP, DNS, RARP, Bonjour, SLP, DDNS
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n
- System Requirements
- Apple MacOS X, HP-UX 11.11, Novell NetWare 6.5, Novell NetWare 5.1 SP6 or later, Novell NetWare 6.0 SP3 or later, HP-UX 11.23, IBM AIX 5.3, SunSoft Solaris x86 10, Red Hat Enterprise Linux WS 4, Novell Open Enterprise Server, SuSE Linux Enterprise Server 11, Microsoft Windows Server 2008 R2, SUSE Linux Enterprise Desktop 11, Debian GNU/Linux 5.0, SUSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Server 10, Red Hat Enterprise Linux WS 5, IBM AIX 6.1, Microsoft Windows Vista (32/64 bits), HP-UX 11.31, Linspire 6.0, Red Flag Linux Desktop 6.0, openSUSE 11.3, Linux Linpus Desktop 9.6, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), SunSoft Solaris SPARC Platform Edition 9, SunSoft Solaris SPARC Platform Edition 10, Red Hat Fedora 14, Red Hat Fedora 15, openSUSE 11.4, IBM AIX 7.1, Ubuntu 11.04, Linux Mint 11, SunSoft Solaris x86 11, Ubuntu 11.10, Debian GNU/Linux 6.0, Linux Mint 9, Linux Mint 10, Red Hat Enterprise Linux WS 6, Ubuntu 12.04, openSUSE 12.1, PCLinuxOS 2011.9, Linux Mint 12
- Designed For
- Lexmark C746, C792, C9235, C950, M5163, M5170, MS710, MS711, MS811, MS812, MS817, MS818, MS823, MS911, MX711, MX717, MX718, MX810, MX811, MX812, MX910, MX911, MX912, X746, X748, X792, X925, X950, X954, XC9235, XC9245, XC9255, XC9265, XM5163, XM5170, XM7155, XM7163, XM7170, XM9145, XM9155, XM9165
- Print server
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 72 Mbps
- Remote Management Protocol
- Telnet, SNMP 3, HTTP, HTTPS, TFTP, IPP 1.0, IPP 1.1, IPP 2.0
- Frequency Band
- 2.4 GHz
- 1 x aerial - RP-SMA
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, SSL, TLS, WPA2
- OS Required
- Designed For
- Lexmark C746dn, C746n, C792dhe, C792dte, C9235, C950DE, C950dte, M5155, M5163, M5170, MS710dn, MS711dn, MS810de, MS810dn, MS810dtn, MS810n, MS811dn, MS811dtn, MS811n, MS812de, MS812dn, MS812dtn, MS817dn, MS817n, MS818dn, MS823dn, MS911de, MX710de, MX710dhe, MX711de, MX711dhe, MX711dthe, MX717de, MX718de, MX810de, MX810dfe, MX810dme, MX810dte, MX810dtfe, MX810dtme, MX810dtpe, MX810dxe, MX810dxfe, MX810dxme, MX810dxpe, MX811de, MX811dfe, MX811dme, MX811dpe, MX811dte, MX811dtfe, MX811dtme, MX811dtpe, MX811dxe, MX811dxfe, MX811dxme, MX811dxpe, MX812de, MX812dfe, MX812dme, MX812dte, MX812dtfe, MX812dtme, MX812dtpe, MX812dxe, MX812dxfe, MX812dxme, MX812dxpe, MX910de, MX910dte, MX910dxe, MX911de, MX911dte, MX912de, MX912dxe, X746de, X748de, X748dte, X792de, X792dtfe, X792dtme, X925de, X950DE, X950dte, X954DHE, XC9235, XC9245, XC9255, XC9265, XM5163, XM5170, XM7155, XM7155x, XM7163, XM7163x, XM7170, XM7170x, XM9145, XM9155, XM9165
