Lexmark Maintenance Fuser Kit MX710/711
Quicklinx: CQV9WS00 Mfr#: 40X8421
Type: Fuse kit
£250.34 ex VAT
£300.40 inc VAT
Lexmark printer maintenance fuser kit LRP - for Lexmark MS811, MS812, MX711, MX810, MX811, MX812, XM5163, XM5170, XM7155, XM7163, XM7170
  • Replacing fuser maintenance kits
    There are multiple warnings to indicate that the fuser is nearing end of life and that a maintenance kit is required, including error codes 80.0x, 80.1x and 80.2x. If you receive error code 80.3x, the fuser has reached its rated life and the printer stops until a maintenance kit is installed. You must install the correct Fuser Maintenance Kit for the type of fuser that is installed in the printer.
  • Lexmark Return Programme
    Lexmark Return Programme fusers are patented devices that are sold at a special price subject to the restriction that the fuser may be used only once. Following the initial use, the customer agrees to return the fuser only to Lexmark for remanufacture and/or recycling. The Return Programme fusers are designed to stop working once they reach their respective rated life (as established by Lexmark).
Lexmark - printer maintenance fuser kit - LRP
Printer maintenance fuser kit (220 - 240 V)
Printing Technology
Laser
Yield
Up to 200000 pages
Pricing Type
Lexmark Return Program (LRP)
Compatible with
Lexmark M5155, M5163, M5170, MS810, MS811, MS812, MX710, MX711, MX810, MX811, MX812, XM5163, XM5170, XM7155, XM7163, XM7170
Consumable
Consumable Type
Printing Technology
Laser
Yield
Up to 200000 pages
Pricing Type
Compatible with
Lexmark M5155, M5163, M5170, MS810de, MS810dn, MS810dtn, MS810n, MS811dn, MS811dtn, MS811n, MS812de, MS812dn, MS812dtn, MX710de, MX710dhe, MX711de, MX711dhe, MX711dthe, MX810de, MX810dfe, MX810dme, MX810dpe, MX810dte, MX810dtfe, MX810dtme, MX810dtpe, MX810dxe, MX810dxfe, MX810dxme, MX810dxpe, MX811de, MX811dfe, MX811dme, MX811dpe, MX811dte, MX811dtfe, MX811dtme, MX811dtpe, MX811dxe, MX811dxfe, MX811dxme, MX811dxpe, MX812de, MX812dfe, MX812dme, MX812dpe, MX812dte, MX812dtfe, MX812dtme, MX812dtpe, MX812dxe, MX812dxfe, MX812dxme, MX812dxpe, XM5163, XM5170, XM7155, XM7155x, XM7163, XM7163x, XM7170, XM7170x
Type: Fuse kit
Brand: Lexmark
