Lexmark printer maintenance fuser kit LRP - for Lexmark MS811, MS812, MX711, MX810, MX811, MX812, XM5163, XM5170, XM7155, XM7163, XM7170
Replacing fuser maintenance kits
There are multiple warnings to indicate that the fuser is nearing end of life and that a maintenance kit is required, including error codes 80.0x, 80.1x and 80.2x. If you receive error code 80.3x, the fuser has reached its rated life and the printer stops until a maintenance kit is installed. You must install the correct Fuser Maintenance Kit for the type of fuser that is installed in the printer. -
Lexmark Return Programme
Lexmark Return Programme fusers are patented devices that are sold at a special price subject to the restriction that the fuser may be used only once. Following the initial use, the customer agrees to return the fuser only to Lexmark for remanufacture and/or recycling. The Return Programme fusers are designed to stop working once they reach their respective rated life (as established by Lexmark).
- Lexmark - printer maintenance fuser kit - LRP
- Product Type
- Printer maintenance fuser kit (220 - 240 V)
- Printing Technology
- Laser
- Yield
- Up to 200000 pages
- Pricing Type
- Lexmark Return Program (LRP)
- Compatible with
- Lexmark M5155, M5163, M5170, MS810, MS811, MS812, MX710, MX711, MX810, MX811, MX812, XM5163, XM5170, XM7155, XM7163, XM7170
Consumable
- Consumable Type
- Laser
- Yield
- Pricing Type
- Compatible with
- Lexmark M5155, M5163, M5170, MS810de, MS810dn, MS810dtn, MS810n, MS811dn, MS811dtn, MS811n, MS812de, MS812dn, MS812dtn, MX710de, MX710dhe, MX711de, MX711dhe, MX711dthe, MX810de, MX810dfe, MX810dme, MX810dpe, MX810dte, MX810dtfe, MX810dtme, MX810dtpe, MX810dxe, MX810dxfe, MX810dxme, MX810dxpe, MX811de, MX811dfe, MX811dme, MX811dpe, MX811dte, MX811dtfe, MX811dtme, MX811dtpe, MX811dxe, MX811dxfe, MX811dxme, MX811dxpe, MX812de, MX812dfe, MX812dme, MX812dpe, MX812dte, MX812dtfe, MX812dtme, MX812dtpe, MX812dxe, MX812dxfe, MX812dxme, MX812dxpe, XM5163, XM5170, XM7155, XM7155x, XM7163, XM7163x, XM7170, XM7170x
