Lexmark Forms Printer 2590n+ Mono Dot-Matrix Printer
Quicklinx: DQLCWS00 Mfr#: 11C2842
The network-ready Lexmark Forms Printer 2590n+ provides high-quality forms printing and features such as high-yield ribbons, multi-font document support and character and page monitoring.
  • Reliability and performance
    Print speeds up to 556 cps at 12 cpi and a rugged design that can handle extreme environments and workloads help you to be productive no matter where you are.
  • Flexible paper handling
    Easily switch between push and pull feeds and print on multiple types of media, including single-part or multi-part continuous forms, sheet-fed paper, and single-part or multi-part cut forms.
  • Easy to use
    The easy-to-use operator panel lets you access all of the printer functions, monitor character and page counts and preview fonts.
  • Easy to maintain
    Easily maintain multiple devices from a centralised location with Lexmark Markvision Enterprise.
  • High-quality and long lasting
    Print near letter-quality multi-font documents and replace supplies less often. Powerful printheads last up to 300 million characters and re-inking ribbons that print up to 8 million characters are available.
Lexmark Forms Printer 2590n+ - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - B/W
8 kg
Max Media Size
297 x 559 mm
Min Media Size (Custom)
76 mm x 76 mm
Max Media Size (Custom)
297 mm x 559 mm
Print Speed
Up to 556 char/sec - fast draft , Up to 480 char/sec - draft , Up to 160 char/sec - near letter
Max Resolution (B&W)
360 dpi
USB, LAN
RAM Installed (Max)
512 KB
Language Simulation
IBM PPDS, EPSON
Media Type
Plain paper, continuous forms
Media Handling
Front paper feeder
Print server - Ethernet, Fast Ethernet
Microsoft Windows 2000, SunSoft Solaris 8, IBM AIX 5.2, IBM AIX 5.1, HP-UX 11.11, SunSoft Solaris 9, SuSE Linux Enterprise Server 8, Red Hat Enterprise Linux WS 3, SunSoft Solaris 10, IBM AIX 5.3, SuSE Linux Enterprise Server 9, SunSoft Solaris x86 10, Red Hat Enterprise Linux WS 4, SuSE Linux 10.0, SuSE Linux Enterprise Server 11, Microsoft Windows Server 2008 R2, SuSE Linux 10.1, Debian GNU/Linux 3.1, SuSE Linux Enterprise Server 10, Red Hat Enterprise Linux WS 5, SuSE Linux 10.2, Debian GNU/Linux 4.0, Linspire 5.0, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
1-year warranty
49.2 cm x 29 cm x 19.5 cm
Printer Type
Workgroup printer - dot-matrix - 24 pin - monochrome
Printer
Print Speed
Up to 556 char/sec - fast draft - 12 cpi , Up to 480 char/sec - draft - 12 cpi , Up to 160 char/sec - near letter - 12 cpi
Wired
USB, LAN
360 dpi
Language Simulation
IBM PPDS, EPSON
Media Handling
Front paper feeder
RAM
RAM Installed (Max)
512 KB
Media Handling
Media Type
Max Media Size
297 x 559 mm
76 mm x 76 mm
297 mm x 559 mm
Media Sizes
297 x 559 mm, 76 x 76 mm
Media Weight
60 g/m² - 90 g/m²
Max Sheets in Multi-Part Form
6
Print server
Network / Transport Protocol
TCP/IP, IPX/SPX, ICMP/IP, LPR/LPD, FTP, DHCP, DNS
Remote Management Protocol
SNMP 1, SNMP 3, IPP, SNMP 2c, HTTP, NDS, HTTPS, TFTP
Security Protocols & Features
SSL, LEAP, TLS, IPsec, 802.1x
1 x USB - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x ribbon (black) - up to 4 million characters
MTBF
12,500 hour(s)
FCC Class B certified, CSA, TUV GS, VCCI, C-Tick, SEMKO, CB, UL 60950-1, IEC 60950-1
Power supply
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site
10 °C
8 - 90%
Sound Emission (Idle)
15 dBA
Sound Emission (Operating)
55 dBA
49.2 cm
29 cm
19.5 cm
8 kg
Width (Shipping)
60.9 cm
Depth (Shipping)
40.8 cm
Height (Shipping)
32.5 cm
Weight (Shipping)
10.3 kg
DQLC Lexmark 23XX 24XX Standard Ribbon In Stock £12.73
DQLC Lexmark 24XX High Yield Ribbon In Stock £21.28
