Lexmark CX727de Colour Laser Multifunction Printer
Quicklinx: D650WS00 Mfr#: 40CC587
Functionality: Copier, Fax, Printer, Scanner
Output Type: Colour
Technology: Laser
Max Print Speed: 47ppm
Hurry, only 1 left in stock!
£1,184.15 ex VAT
£1,420.98 inc VAT
Lexmark's CX727de is a very fast color MFP that prints up to 47 ppm and scans up to 56 sides or images per minute.
  • Quad core power
    A 1.2 GHz quad core processor with up to 4 GB of memory gives the CX727de fast and powerful print capabilities.
  • Exceptional color
    Professional color features including ultra-sharp 4800 Color Quality, PANTONE calibration and Lexmark Color Replacement work with Unison Toner to deliver precision matching for critical colors.
  • Solutions flexibility
    Lexmark's Embedded Solutions Framework applications let you run software solutions to meet the needs of your industry.
  • Versatile media handling
    Media loading and feeding are engineered for ease, reliability and versatility, with up to 650 pages of input capacity (expandable to 2,300), small-media and banner-length support, and exceptionally durable input trays that resist misfeeds.
  • Light touchscreen
    A bright, 17.8 cm e-Task color touch screen features an ultra-smooth surface and can be activated by almost anything, including pens, fingertips or nails - without pressure or direct skin contact.
  • Advanced scanning
    Automatic de-skew, mixed-size scanning, page-level jam recovery and integrated file compression make the CX727de a scanning workhorse.
Lexmark CX727de - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
150000 pages
Recommended Monthly Volume
2000 - 20000 pages
Max Copying Speed
Up to 47 ppm (mono) / up to 47 ppm (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi (300 x 300 dpi colour)
Display
7"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, card stock
Standard Media Capacity
650 sheets
Max Media Capacity
2300 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
300 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to network, scan to FTP
50.55 cm x 53.3 cm x 64.8 cm
44.9 kg
Environmental Standards
ENERGY STAR Qualified
4 years warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
150000 pages
2000 - 20000 pages
Display Diagonal Size
7"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
2 GB
Max Supported Memory
4 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PPDS, PDF 1.7, XPS
Image Enhancement Technology
4800CQ
Automatic Duplexing
First Print Out Time B/W
5 sec
First Print Out Time Colour
5.5 sec
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Machine Features
Colour faxing
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
218 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), US No 9 (98.6 x 225.6 mm)
650 sheets
Max Media Capacity
2300 sheets
100 sheets
300 sheets
Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 218 g/m² , Input tray - 550 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 218 g/m² , ADF - 50 sheets , Output tray - 300 sheets
Speed Details
Printing: up to 47 ppm (A4) - B/W , Printing: up to 47 ppm (A4) - colour , Printing: up to 38 spm (A4) - B/W duplex , Copying: up to 47 ppm (A4) - B/W , Copying: up to 47 ppm (A4) - colour , Scanning: up to 56 spm (A4) - B/W , Scanning: up to 56 spm (A4) - colour , Scanning: up to 26 spm (A4) - B/W duplex , Scanning: up to 28 spm (Letter A) - B/W duplex , Scanning: up to 26 spm (A4) - colour duplex , Scanning: up to 28 spm (Letter A) - colour duplex , Scanning: up to 60 spm (Letter A) - B/W , Scanning: up to 60 spm (Letter A) - colour
1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, Apple Bonjour, TLS, ARP
Operating System Support
MS Windows XP, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Vista (64-bit versions), Sun Solaris 10, MS Windows Server 2008, Novell NetWare 6.5, IBM AIX 6.1, MS Windows Server 2008 R2, IBM AIX 7.1, MS Windows Server 2012, Windows 8, Windows RT, Windows 8 64-bit, Windows 8.1, Windows 8.1 64-bit, MS Windows Server 2012 R2, Windows RT 8.1, Sun Solaris 11, Windows 10, Novell Open Enterprise Server 2, Novell Open Enterprise Server 11
700 Watt
Power Consumption Standby
100 Watt
Power Consumption Sleep
2.6 Watt
First Copy Out Time B/W
6.5 sec
First Copy Out Time Colour
7 sec
Phone cable
Consumables Included
1 x Cartridge (black) - up to 7000 pages , 1 x Cartridge (cyan) - up to 3000 pages , 1 x Cartridge (magenta) - up to 3000 pages , 1 x Cartridge (yellow) - up to 3000 pages
FCC Class B certified, CSA, UL, VCCI Class B ITE, CISPR 22 Class B, DEMKO, GS, EN55024, IEC 60320-1, EN55022 Class B, CB, ICES-003 Class B, C-Tick Class B, MIC, EK, UL 60950-1, IEC 60950-1, EN 60950-1, CCC Class B, BSMI Class B, IEC 60825-1, FDA, CAN/CSA C22.2 No. 60950-1
ENERGY STAR Certified
Limited warranty - 4 Years
50.55 cm
53.3 cm
64.8 cm
44.9 kg
Shipping Width
70 cm
Shipping Depth
73.5 cm
Shipping Height
95.5 cm
Shipping Weight
64 kg
Sound Emission
53 dBA (operating)
10 °C
32 °C
8 - 80%
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Technology: Laser
Brand: Lexmark
Price Range Ex VAT: 1000 - 1500
