The C792de combines a robust design, exceptional media handling, two-sided printing and an intuitive color touch screen to deliver your workgroup brilliant color laser printing.
The 4.3-inch color touch screen allows you to operate your printer with ease and confidence through smart and intuitive navigation, easy access to workflow solutions and shortcuts, and the ability to preview your documents and print jobs at the device.
Ultra-reliable paper feeding to support diverse media, including card stock, labels, UV-resistant outdoor media, banner media and more. Reduce unnecessary printing and simplify work processes through solutions applications preloaded on your device.
Flexible, Robust Colour Printing
The C792de combines a robust design, exceptional media handling, two-sided printing and an intuitive colour touch screen to deliver your workgroup brilliant colour laser printing. -
Intuitive Colour Touch Screen
The 10.9 cm (4.3 inch) colour touch screen allows you to operate your printer with ease and confidence through smart and intuitive navigation, easy access to workflow solutions and shortcuts, and the ability to preview your documents and print jobs at the device. -
Expandable Input and Flexible Output Options
Print on multiple paper types and boost total capacity up to 3,200 sheets. Choose from four output options, including a five-bin mailbox, an offset stacker, a staple finisher, and a staple with hole punch finisher. -
Exceptional Media Handling
Ultra-reliable paper feeding to support diverse media, including card stock, labels, UV-resistant outdoor media, banner media and more. -
Lexmark Solutions
Reduce unnecessary printing and simplify work processes through solutions applications preloaded on your device. Choose additional Lexmark solutions to fit your unique workflow needs. -
Long-lasting Toner
The Lexmark Extra High Yield Print Cartridge delivers up to 20,000 pages, reducing interventions, cartridge waste and cost. Average continuous black or composite CMY declared cartridge yield in accordance with ISO/IEC 19798.
- Lexmark C792de - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 50 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 47 ppm - B/W - A4 (210 x 297 mm) , Up to 47 ppm - colour - A4 (210 x 297 mm) , Up to 47 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 50 ppm - colour - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Max Resolution (Colour)
- 2400 x 600 dpi
- Image Enhancement Technology
- 4800 Color Quality
- Automatic Duplexing
- Interface
- USB, Gigabit LAN, USB host
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 512 MB (1.5 GB)
- Language Simulation
- PCL 5E, PCL 5C, PostScript 3, PCL 6, IBM PPDS, XPS, PDF 1.6, xHTML
- Media Type
- Envelopes, transparencies, labels, plain paper, cards, banner paper
- Total Media Capacity
- 650 sheets
- Media Handling
- 100-sheet multipurpose tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 150000 pages
- Recommended Monthly Volume
- 2500 - 17000 pages
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- SunSoft Solaris 8, IBM AIX 5.2, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, HP-UX 11.11, SunSoft Solaris 9, Microsoft Windows Server 2003, Novell NetWare 6.5, Novell NetWare 5.1 SP6 or later, Novell NetWare 6.0 SP3 or later, HP-UX 11.23, SunSoft Solaris 10, Microsoft Windows 7, IBM AIX 5.3, SunSoft Solaris x86 10, Red Hat Enterprise Linux WS 4, Linux Linpus, Novell Open Enterprise Server, Microsoft Windows Vista, SuSE Linux Enterprise Server 11, Ubuntu 9.04, SUSE Linux Enterprise Desktop 11, Debian GNU/Linux 5.0, SUSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Server 10, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Red Hat Enterprise Linux WS 5, Microsoft Windows Server 2008, IBM AIX 6.1, Microsoft Windows Server 2008 x64 Edition, HP-UX 11.31, Ubuntu 9.10, openSUSE 11.2, Red Hat Fedora Core 12, Red Flag Linux Desktop 6.0, Red Hat Fedora 13, openSUSE 11.3, Ubuntu 10.04
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 56.6 cm x 51.2 cm x 51.5 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 2400 x 600 dpi
- 2400 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 8 sec
- First Print Out Time Colour
- 8.5 sec
- Fonts Included
- 39 x scalable PPDS , 5 x bitmapped PPDS , 158 x scalable PostScript , 84 x scalable PCL , 2 x bitmapped PCL
- Media Handling
- Processor
- 1.2 GHz
RAM
- 512 MB / 1.5 GB (max)
- Slots Qty
- 1
- Empty Slots
- 1
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), US No 9 (98.6 x 225.6 mm)
- 650 sheets
- Media Feeders
- 1 x automatic - 100 sheets , 1 x automatic - 550 sheets
- Max Media Capacity
- 3200 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 150000 pages
- Networking
- Print server
- Data Link Protocol
- TCP/IP, AppleTalk, UDP/IP, NTP, ICMP/IP, LPR/LPD, ARP, FTP, BOOTP, DHCP, DNS, RARP, Bonjour, DDNS
- Remote Management Protocol
- Telnet, SNMP 3, SNMP 2c, HTTP, NDPS, NDS, HTTPS, TFTP, IPP 1.1
- SSL, Apple Bonjour, LEAP, TLS, IPsec, 802.1x
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x direct print port - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
- FCC Class A certified, TUV GS, CISPR 22 Class A, BSMI CNS 13438 Class A, IEC 825-1/EN 60825-1 class 1, VCCI Class A ITE, EN55024, EN55022 Class A, IEC 60320-1, AS/NZS 60950-1, CCC, PSB, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07, TUV Rh, A-Tick, FDA, N-mark, UL-AR, GOST-R
- Power Device
- Power supply - internal
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site - response time: next business day
- 16 °C
- 32 °C
- 8 - 80%
- Sound Emission (Idle)
- 29 dBA
- Sound Emission (Operating)
- 53 dBA
- Sound Emission (Quiet Mode)
- 48 dBA
- 56.6 cm
- 51.2 cm
- 51.5 cm
- 50 kg
- Width (Shipping)
- 76 cm
- Depth (Shipping)
- 70 cm
- Height (Shipping)
- 84.5 cm
