Start your color journey with the Lexmark C2425dw, the small-workgroup printer that helps you control the cost of color output of up to 25 ppm.
                4-year guarantee upon registrationFor an added level of peace of mind, you can benefit from a 4-year guarantee coverage upon registration.
                Engineered to lastA steel frame, long-life imaging system and robust paper feeding system that reliably handles diverse media types and sizes, all support lasting performance in any environment.
                Interact with easeWith its small footprint, it's easy to find a place for. And the new front-panel power button and direct-print USB port, 2.4-inch colour LCD with keypad and secure browser-based device management make it easy to interact with.
                Colour that only looks expensiveThanks to PANTONE calibration, embedded colour sample pages and Lexmark colour Replacement, you'll get accurate, professional colour in-house. And you'll save toner with included tools that let you choose when and how much colour to print, including mono-only print drivers, user-based colour print permissions, global colour density control, object-specific colour Saver, proof before printing and more.
                Classic connections, wireless convenienceBeyond included USB and gigabit ethernet, this device lets you connect wirelessly via built-in Wi-Fi, as well as AirPrint, Google Cloud Print, and Mopria on any network with existing Wi-Fi access. And with Lexmark Mobile Print, printing's as easy as hitting print, choosing your printer and picking up your job.
                Energy efficiencyMake every watt count with energy management features that reduce power consumption whether the device is active or in sleep mode. Lower fusing temperature, automatic management of processor cores based on workload, and standard two-sided printing all help it achieve EPEAT Silver rating and ENERGY STAR (2.0) certification. That benefits the planet and your budget.
                Full-spectrum securityLexmark's comprehensive approach to product security is a design and engineering mandate across our entire product portfolio. Our security features help keep your information safe - in the document, on the device, over the network and at all points in between. That's why Keypoint Intelligence - Buyers Lab honoured Lexmark with a prestigious BLI PaceSetter award for Document Imaging Security. And this Lexmark product enables you to be GDPR ready.
- Lexmark C2425dw - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 21 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 23 ppm - B/W - A4 (210 x 297 mm) , Up to 23 ppm - colour - A4 (210 x 297 mm) , Up to 12 spm - B/W duplex - A4 (210 x 297 mm) , Up to 12 spm - colour duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Max Resolution Class (B&W)
- 1200 x 1200 dpi
- Max Resolution Class (Colour)
- 1200 x 1200 dpi
- Image Enhancement Technology
- 4800 Color Quality
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB 2.0 host
- AirPrint Enabled
- Preview Screen Size
- 2.4"
- Processor
- 1000 MHz
- RAM Installed (Max)
- 512 MB (512 MB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, XPS, PDF 1.7
- Media Type
- Envelopes, labels, plain paper, card stock
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet manual tray
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 800 - 6500 pages
- Networking
- Print server
- System Requirements
- SunSoft Solaris x86 10, SuSE Linux Enterprise Server 11, Apple MacOS X 10.6, SuSE Linux Enterprise Server 10, IBM AIX 6.1, Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, IBM AIX 7.1, SunSoft Solaris x86 11, Red Hat Enterprise Linux WS 6, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Debian GNU/Linux 7.0, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10, SuSE Linux Enterprise Server 12, Apple MacOS X 10.11, Debian GNU/Linux 8.0, Red Hat Enterprise Linux WS 7, Ubuntu 16.04 LTS, SUSE Linux 13.2, Apple macOS 10.12, Linux Fedora 23, Linux Fedora 24, openSUSE 42.3
- 4 years warranty
- 44.2 cm x 42.1 cm x 30.8 cm
- Printer Type
Printer
- Print Speed
- 2.4"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 10.1 sec
- First Print Out Time Colour
- 10.1 sec
- Media Handling
- Processor
- 1000 MHz
RAM
- 512 MB / 512 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- 250 sheets
- Media Feeders
- Bypass tray: 1 - 1 sheet , Input tray: 1 - 250 sheets , Output tray: 1 - 125 sheets
- Max Media Capacity
- 900 sheets
- Output Trays Capacity
- 125 sheets
Duty Cycle
- 75000 pages
- 800 - 6500 pages
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (cyan) - up to 750 pages , 1 x toner cartridge (magenta) - up to 750 pages , 1 x toner cartridge (yellow) - up to 750 pages , 1 x toner cartridge (black) - up to 1400 pages , 1 x photoconductor unit
- FCC Class B certified, ICES-003 Class B, CCC, DOC, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI Class B, KCC, IEC 60825-1, FDA, UL-AR, EN 60825-1, KC, CECP, CEL, VCCI Class B, Directive 1275/2008/EC, EFTA, CAN/CSA-C22.2 No. 60950-1
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 4 Years
- 10 °C
- 32 °C
- 8 - 80%
- Sound Emission (Operating)
- 48 dBA
- 44.2 cm
- 42.1 cm
- 30.8 cm
- 21 kg
