Quickly and securely transfer photos, videos, and files with the affordable, high-performance Lexar JumpDrive S25 USB 3.0 drive. It features a slim, retractable design.
Store and transfer content faster
With a busy life on the go and so much to do, the last thing you want is to spend extra time waiting for your files to transfer. With JumpDrive S25 you can transfer files faster. -
Designed for convenience
Beyond its performance and good looks, JumpDrive S25 is designed for convenience. Its small, slim retractable design means there's no cap to lose. It also has a key ring loop so you can easily attach it to your keychain, computer bag, backpack, or purse. -
Colorful style
Lexar JumpDrive S25 features a great color coding system to help you organize your drives and their contents. -
Lexar performance, quality, compatibility, and reliability
All Lexar USB flash drives ensure performance, quality, compatibility, and reliability. This provides customers with a high level of confidence when using Lexar products to capture, manage, move, and store the memories that matter.
- Lexar JumpDrive S25 - USB flash drive - 64 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 64 GB
- Encryption Algorithm
- 256-bit AES
- Enclosure Colour
- Purple
- Software Included
- EncryptStick Lite
- 3-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 64 GB
- 256-bit AES
- Enclosure Colour
- Purple
- Read Rate
- Up to 150 MB/s
- Write Rate
- Up to 60 MB/s
- Interface Type
- USB 3.0
- Retractable connector, key ring loop
- Software Included
- EncryptStick Lite
- Limited warranty - 3 years
