Brand
Lexar USB 3.0  25-in-1 Multi Card Reader
Quicklinx: 8FLRWS00 Mfr#: LRW025URBEU
£18.20 ex VAT
£21.84 inc VAT
The Lexar multi-card 25-in-1 USB 3.0 reader is an easy-to-use, all-in-one file transfer solution. The reader has a pop-up design, supports 25 memory card formats, and enables concurrent downloads and card-to-card file transfer.
  • Supports multiple card formats for impressive versatility
    The Lexar multi-card 25-in-1 USB 3.0 reader has five slots and supports more than two dozen of the most popular card formats, making it easy to transfer files between your digital camera, MP3 player, mobile phone, and computer.
  • Quickly transfer files with USB 3.0 technology
    Now you can take advantage of the USB 3.0 port in your laptop or computer. The Lexar multi-card 25-in-1 USB 3.0 reader leverages SuperSpeed USB 3.0 technology to provide high-speed transfer with a USB interface speed up to 500 Mbps. With read speeds up to 5x faster than USB 2.0, this means you can quickly transfer your photo, video, music, and other files from device to computer. Simply remove the card from your digital device, slide it into the reader, and drag and drop files onto your computer. And for added convenience, the reader is also backwards compatible with USB 2.0 ports.
  • Enables concurrent downloads and card-to-card file transfer
    The reader also has the ability to read multiple cards from multiple card slots simultaneously, and allows for card-to-card file transfer between cards in different slots - further enhancing its versatility. This gives you the power to share photos, videos, music, and files among your devices.
  • Pop-up design
    Created with convenience in mind, the Lexar multi-card 25-in-1 USB 3.0 reader boasts a pop-up mechanism that allows you to open and close the reader with a simple push, protecting the card slots when not in use. As for looks, the reader's designed to be a great addition to your workspace with its sleek, glossy finish, and it sports a cool blue LED activity light to let you know when file transfer is complete.
  • Lexar performance, quality, and reliability
    With support for multiple memory card formats, the ability to perform concurrent downloads and card-to-card file transfer, and a protective pop-up design, the Lexar multi-card 25-in-1 USB 3.0 reader is an excellent, all-in-one solution to your file transfer needs. The reader provides you with performance, quality, and reliability from the brand you can trust.
Lexar Multi-Card Reader card reader - USB 3.0
Card reader - external - 25 in 1
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, miniSD, RS-MMC, microSD, MultiMediaCardplus, xD-Picture Card Type M+, SDHC Memory Card, miniSDHC, Memory Stick Micro (M2), microSDHC, Memory Stick PRO-HG Duo, xD-Picture Card Type H, xD-Picture Card Type M, SDXC Memory Card
Host Interface
USB 3.0
Microsoft Certification
Compatible with Windows 7
1-year warranty
Host Interface
USB 3.0
Memory Card
(max)
Required Ports
1 x 9 pin USB Type A
USB cable
Limited warranty - 1 year
Supported Formats: CompactFlash Card type I
Supported Formats: CompactFlash Card type II
Supported Formats: Memory Stick PRO
Supported Formats: Memory Stick PRO-HG Duo
Supported Formats: MultiMediaCard
Supported Formats: RS-MMC
Supported Formats: microSD
Supported Formats: microSDHC
Supported Formats: Memory Stick Duo
Supported Formats: Memory Stick Micro (M2)
Supported Formats: SD Memory Card
Supported Formats: SDHC Memory Card
Supported Formats: Memory Stick PRO Duo
Supported Formats: miniSD
Supported Formats: xD-Picture Card Type H
Supported Formats: xD-Picture Card Type M+
Supported Formats: MultiMediaCardplus
Supported Formats: miniSDHC
Supported Formats: SDXC Memory Card
Interface: USB 3.0
Brand: Lexar
