Lexar MicroSD to Lightning Card Reader
Quicklinx: C5VLWS00 Mfr#: LRWMLBEU
  • Easily transfer content to and from your iPhone or iPad with a microSD card
  • Compact, portable design with Lightning connector
  • Use free file management app (App Store)
  • Automatic and secure synchronizing of files
  • Easily offload content to your iPhone or iPad
    Capturing life in action? Easily offload content from your sports camcorder or aerial camera to your iPhone or iPad with the Lexar microSD Reader. This small, portable reader features a Lightning connector, providing quick file transfer, wherever adventure may take you.
  • Save time by offloading on the go
    With its Lightning connector, the reader makes it easy to move all your favorite content to your iOS device on the go. So whether you're offloading stunning action photos or epic adventure video, it's got you covered.
  • View and play back photos and videos - anywhere
    The microSD Reader is easy to take on the go, so you can view and play back content from your iOS device, wherever you are.
  • Expand the memory of your devices
    By offloading your files, you can store more on your microSD card, giving you the extra space you need to capture more of the content you crave.
  • Multitasking made easy
    Made for more than just offloading adventure, the reader also provides a simple way to move files from any Android or other microSD-based device to your iPhone or iPad. It's also a great way to swap content between your iOS devices.
  • Small, portable design
    With its small footprint, you can put it in your pocket and go. And the Lightning connector fits with most iOS cases, providing simple plug-and-play functionality.
  • Automatically and securely sync your photos and video
    The microSD reader works with use of a free, easy-to-use file management app on the App Store. The app also allows you to back up files when connected, for peace of mind on the go.
Lexar card reader - Lightning
Card reader - external
Supported Memory Cards
microSD
Host Interface
Lightning
1-year warranty
microSD
Host Interface
Lightning
Memory Card
(max)
Required Ports
1
Plug and Play
Limited warranty - 1 year
