Lexar JumpDrive S45 64GB USB3.0
Quicklinx: C5VHWS00 Mfr#: LJDS45-64GABEU
Easily expand the storage capabilities of your devices with the low-profile, plug-and-stay Lexar JumpDrive S45 USB 3.0 flash drive. Quickly and securely store and transfer photos, videos, and files at USB 3.0 speeds - up to 150 MB/s read and 45 MB/s write.
Easily expand the storage capabilities of your laptop, TV, or car stereo system with JumpDrive S45. Its compact, low-profile design means you can plug it in and forget it - it's always at the ready for storing and accessing files.
  • Plug-and-stay storage for your favorite devices
  • Store and transfer content at USB 3.0 speeds
    Who wants to spend extra time waiting for files to transfer? JumpDrive S45 provides speeds up to 150MB/s read and 45MB/s write. Quickly transfer a large HD video clip in less than 90 seconds, compared to more than 4 minutes using a standard USB 2.0 drive. And for added versatility, the drive is backwards compatible with USB 2.0 devices.
  • Securely protect your files
    JumpDrive S45 includes software which is an advanced security solution with 256-bit AES encryption to help protect your essential files against corruption, loss, and deletion. Easily create a password-protected vault that automatically encrypts data. And for peace of mind, files that are deleted from the vault are securely erased and can't be recovered.
Lexar JumpDrive S45 - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
64 GB
Encryption Algorithm
256-bit AES
Enclosure Colour
Teal
Software Included
EncryptStick Lite
3-year warranty
USB flash drive
Storage Capacity
64 GB
256-bit AES
Enclosure Colour
Teal
Read Rate
Up to 150 MB/s
Write Rate
Up to 45 MB/s
Interface Type
USB 3.0
Key ring loop
Software Included
EncryptStick Lite
Limited warranty - 3 years
