Lexar JumpDrive C20i 16GB
Quicklinx: C5V3WS00 Mfr#: LJDC20I-16GBBEU
With today's overflow of content - created, captured, and consumed - it's easy to run out of space on your iPhone or iPad. So you don't need to delete your favorite photos and videos to make room for more. The multitasking Lexar JumpDrive C20i flash drive makes it easy to offload, add, or back up files, as well as charge your iOS devices on the go. No battery needed and no network required.
  • Save space by offloading files from your device
    With both Lightning and USB 3.0 connectors, this high-speed, 3-in-1 iOS flash drive makes it easy to move files on the go, so you have extra space to store more of the content you crave.
  • Play music and videos directly from the drive
    JumpDrive C20i not only makes it easy to offload and transfer files, but it also allows you to listen to your favorite songs and watch videos right from the drive.
  • Easily transfer and share files between your iPhone, iPad, and computer
    Use JumpDrive C20i to easily swap your playlists, photos, videos, and files between your iPhone and iPad, or to your computer.
  • Move files at USB 3.0 speeds
    Powered by USB 3.0 performance, JumpDrive C20i provides high read speeds. And for added versatility, it's backwards compatible with USB 2.0 devices.
  • Convenient cable design
    Multitasking goes upscale with the sleek metal finishing of JumpDrive C20i. It also features a cable clip to keep it folded for storage. The Lightning connector fits with most iOS cases, and with its ability to offload, back up, and charge your iOS devices, it's a true workhorse for road warriors or anyone on the go.
Lexar JumpDrive C20i - USB flash drive - 16 GB
USB flash drive
Interface Type
USB 3.0 / Apple Lightning
Storage Capacity
16 GB
Apple MacOS X or later, Apple iOS 7, Apple iOS 8, Microsoft Windows 7 / 8 / 10
3-year warranty
USB flash drive
Storage Capacity
16 GB
Read Rate
Up to 95 MB/s
Write Rate
Up to 10 MB/s
Interface Type
Metallic finish
Limited warranty - 3 years
