With today's overflow of content - created, captured, and consumed - it's easy to run out of space on your iPhone or iPad. So you don't need to delete your favorite photos and videos to make room for more. The multitasking Lexar JumpDrive C20i flash drive makes it easy to offload, add, or back up files, as well as charge your iOS devices on the go. No battery needed and no network required.
Save space by offloading files from your device
With both Lightning and USB 3.0 connectors, this high-speed, 3-in-1 iOS flash drive makes it easy to move files on the go, so you have extra space to store more of the content you crave. -
Play music and videos directly from the drive
JumpDrive C20i not only makes it easy to offload and transfer files, but it also allows you to listen to your favorite songs and watch videos right from the drive. -
Easily transfer and share files between your iPhone, iPad, and computer
Use JumpDrive C20i to easily swap your playlists, photos, videos, and files between your iPhone and iPad, or to your computer. -
Move files at USB 3.0 speeds
Powered by USB 3.0 performance, JumpDrive C20i provides high read speeds. And for added versatility, it's backwards compatible with USB 2.0 devices. -
Convenient cable design
Multitasking goes upscale with the sleek metal finishing of JumpDrive C20i. It also features a cable clip to keep it folded for storage. The Lightning connector fits with most iOS cases, and with its ability to offload, back up, and charge your iOS devices, it's a true workhorse for road warriors or anyone on the go.
- Lexar JumpDrive C20i - USB flash drive - 16 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0 / Apple Lightning
- Storage Capacity
- 16 GB
- OS Required
- Apple MacOS X or later, Apple iOS 7, Apple iOS 8, Microsoft Windows 7 / 8 / 10
- 3-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- Read Rate
- Up to 95 MB/s
- Write Rate
- Up to 10 MB/s
- Interface Type
- Metallic finish
- OS Required
- Limited warranty - 3 years
